DMR EH50 using Pal Plus set top box stopped getting TV Guide info but I still had channel listing and could record. Although the show scedual was gone there were still lines on the guide for the channels and they all said no listing. But if I selected a time on the guide to record it did record the program and I was able to see it. In an effort to regain the guide I rebooted the Pal Puls and the DMR and now DMR has a flashing clock and there are no channels on the guide or in channel editor. I have rebooted both by holding teh power button down and but holding the up\down channel buttons down.
SOURCE: Panasonic DMR-E85 DVD recorder TV Guide problem
Try unplugging the DMR-E85 power cord. It is important that you unplug it from the back of the recorder, not the wall. Leave it unplugged for 10 or 15 minutes. For good measure disconnect the cable 'in' connection as well. Once both lines are plugged back in it will go through its self-check diagnostics. Leave it alone for awhile (give it time to consider the error of it's ways). If you are lucky, when you turn it back on it will ask you to verify the channel lineup. If this does work, and all the channel info is correct, press 'enter' (lineup 1 highlighted). Good luck! This is an awesome machine, WHEN IT WORKS!
SOURCE: product DMR-EH50, UNABLE TO DOWNLOAD TV GUIDE ON SCREEN SYSTEM.
I think I may have the "answer".
I am in Atlanta and have a
Panasonic DVR that was working fine and sometime during the past month
or so we lost the channel listings. I've tried many resets as well with
negative results.
I called Comcast tonight. The agent helping me
took a long time to research the issue and gave me this answer (which
sounds reasonable). By the way, this is for the Atlanta area and may
not be applicable to other areas of the country.
Due to delays
in the conversion to broadcast digital and the fact that Comcast is
experiencing bandwidth issues, they have digitized the "channel
listing" signal. By mid-June Comcast's signal will be all digital and
you won't be able to watch a TV connected directly to Comcast cable -
regardless of whether it has digital or analog tuner (or both). This is
contrary to what I'd heard before.
After mid-June, you'll either
need to use a cable box OR what she called a "Digital Transmitter
Adapter" (let's call it a DTA). Prior to being converted to "full"
digital, you'll get notification from Comcast. She said I'd be able to
get 2 DTAs at no charge (I currently have one Comcast HD DVR box).
Additional DTAs would be $1.99 a month. DTAs will only provide access
to the "basic" cable channels, but the good news is that the Panasonic
DVR should be able to obtain its channel lineup through this DTA box.
If you have any questions, please feel free to contact me directly at [email protected]
Good Luck!
SOURCE: Unable to view/record cable channels with Panasonic DMR EZ48V
Here is what you will need. This is assuming you do not have a HD cable box.
1) A two port cable splitter available at your local hardware or electronics store. VERY IMPORTANT- this splitter needs to pass up to 1000 mghz so you do not interfere with the functions of the cable box. Also, when purchasing this don't be fooled gold does not always equal good (a common mistake made by folks).
2) 1 small coax cable.
3) 3 Additional coax cables. (1 long enough to reach from the wall to the cable box. 1 long enough to reach from cable box to the TV. 1 long enough to reach from wall to the VCR. These cables should be RG6 coax cable (about the width of a standard wooden pencil)
4) 2 RCA cables (Yellow/Red/White)
Here is how you need to connect the cables....
1) Use the small coax cable and connect it from the WALL to the INPUT of the two way SPLITTER.
2) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the CABLE BOX.
3) Use one of the coax cables and connect it to the OUTPUT of the CABLE BOX to the INPUT of the TV.
4) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the VCR.
5) Use one of the RCA cables and connect to the DVD/VHS COMMON OUT on the VCR. Connect the other end of this cable to the VIDEO IN on the back of the TV.
6) Use the other RCA cable and connect it to the VIDEO OUT on the back of the CABLE BOX. Connect the other end to the IN 1 on the back of the VCR.
Here is how to set up the VCR-
1) Tune the TV to the video input that you connected the VCR to.
2) Go to the auto program in the menus for the VCR and select "CABLE" as the source and you should now be able to get all the channels you would normally get without the cable box.
3) This will give you the option to record shows from basic cable on the VCR. While copying these channels you will still be able to tune the TV to CH 3 for the cable box and watch TV normally through the cable box.
4) If you want to copy one of the channels that is only available with the cable box you will still be limited to only being able to watch that channel while it is recording but here is how you will do it.
Hope this has been helpful....
Good Luck....
