SOURCE: dvc 90 does not work with studio 9 in vista
I have strong feeling that this software is incaptiable with vista maybe mite try going to the site of the maker of the software and asking if it is comptiable if not see i you can request a comptiable software that will work oh( make sure before you do you unstall it first) cause the software will crash or fight with each orther I hope this helps lala linda
SOURCE: Dazzle DVC 90 does not work in Vista
Hi there!
Try unplugging the DVC90 and uninstalling it from Device Manager. Then go to the Control Panel and delete all the drivers you find. Reboot and try the installation again. If I remember correctly you can run PCLUSB2.exe first to get the drivers on your hard drive and then plug the device in. When you do that just point the driver install to the folder that the drivers got installed to.
Have fun!
*Your vote is highly appreciated. Thanks in advance!
SOURCE: Capture does not work at all. There is no
Switch your PC on and left click on the control panel,
systems, right click to open, left click device manager. Once the device manager is opened. Find out if your sound, video, and games controller is working alright. Then, get connected to the internet at the microsoft website for the free driver software download for video and sound. Make sure that this is compatible with your existing operating systems.
SOURCE: I have a dazzle 150 I use it when I had Pinnacle
I've been able do download the driver. However, the only way I can get it to you is by email. Send me an email at [email protected] and I'll send it to you as an attachment.
SOURCE: Dazzle DVC-80 on vista thinks that video and audio are both audio
i did install the driver from pinnicle that says it will work up to xp.
its not hard but follow these steps, and ignore all these people that are saying it wont work, and throwing them out.
the problem, the install is not compatible with vista, so you change the compatibility of the file to xp pro. its easy here:
1. download the driver from pinnacle, its: PCLEUSB.exe
2. dont install it yet
3. right mouse click
4. hit the 'compatibility' tab
5. check the 'run this program in compatabilty mode for:'
6. scroll and select 'windows xp (service pack 2)'
7. also check the 'run this program as an administrator box'
8. click the 'apply button'
now:
click and run the file, its going to think its running under xp.
dont plug in the usb for the dazzle. wait for the install the driver.
when its done plug in the dazzle, it will look for the driver it will find it and will install it, since you ran the pcleusb.exe. hell the dazzle thinks its running in xp. now any software will use it and it will be in all you video software as the "dazzle dvc80" in video options and same for audio. works great, clean video and clean audio. just like new.
