problems cam be low fuel flow or most probable overload
It is to be remembered that the started kw out put is not not the continuous rated out put of a gen set so for example a gen set sold as a 3000watt or 3kva has a continuous out put of around 80% of that and if your current draw is at the top end then the engine will be hard pressed to maintain constant frequency which is rpm controlled
www.partsfortechs.com > Home > Generator Part Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t... Jun 8, 2013 - 3 posts - 3 authors
Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
Is it losing Battery power, or just not pumping? check connections, and pins on board connector. Failing that replace the board, if Battery voltage is been lost
i have a onan model5.5 HGJAB-1038C GENERATOR IT SHOWS CODE 14 IT WILL START FOR 15 SECONDS AND WILL STOP -- I HAVE REPLACED THE FILTER, NEW FUEL PUMP. NEW SPARK PLUGS- CLEANED CARB AND STILL NOTHING I AM IN MEXICO AND NO SERVICE PEOPLE I NEED A SERVICE MANUEL FOR THIS UNIT--THANKYOU PLEASE
Surging is fuel issue, carb gummed, pump pressure (there was a series of bad pumps recall) check with your local dealer. There was a PSB depends on your spec number.
Go to the auto parts store and buy a "Battery Tender" solar powered, or get an electric trickle charger. Or install a battery disconnect for the period the unit is not in use; you can disconnect the battery.
