Question about Cameras
My Olympus Tough-3000 will not upload the software the videos and pictures are on the hard drive but not the software
Before I had my computer reinstalled it was good .I just plugged the USB cable into the camera & computer it went perfect. but this time after being reinstalled all it done was upload the videos& pictures but no software..I tried to upload the software first without the SD card in camera, it went through all the motions the pulsing bar etc it took about 60 seconds . Then I installed the SD card the only thing that happened and got only 10 GB of videos& pictures..WHATS GONE WRONG
  • Cameras Master
  • 32,281 Answers
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Posted on Mar 08, 2013
6ya staff
SOURCE:
Marty marty
  • 883 Answers
SOURCE: Can't upload pics; computer not "seeing" camera
The key to getting back to "It used to work fine;" is to make Windows "GO BACK IN TIME" to that moment when it last "It used to work fine;" occurred. How to do that. Try to pinpoint the exact date that it started acting badly. Now do this: START-ALL PROGRAMS-ACCESSORIES-SYSTEM TOOLS-SYSTEM RESTORE. I'm hoping you actually have RESTORE utility turned on...Now select the restore date BEFORE it quit working. DONE! Windows will run as it used to run when all worked well. I use RESTORE all the time and I have 100% success rate!
Posted on Jun 23, 2007
Steve5
Steve Grezoux
  • 423 Answers
SOURCE: cannot upload pics from camera to PC
Hi Ray;
Try uninstalling the Fuji software completely, through the Windows control panel. Don't use the supplied software at all. Make sure the camera is unplugged from the computer. Open "my computer" and note which drives are present. Now plug in the camera (still turned off) to the USB port. Turn the camera power switch on. Wait and see if a new drive icon shows up. It may take a minute or so. If you get a new icon (probably Fuji DSC or similar), you should be able to open the new drive and access the images through the various folders. If not, can you see images on the camera screen (when not connected to computer)? If yes, maybe a bad cable. If no, could be corrupted images on card.
Posted on Feb 05, 2008
Anonymous
  • 73 Answers
SOURCE: My pictures won't download!! I
some comp seem to have problems reading from the olympus cameras. if you have a card reader take the card out and put into that. if not you can get one cheap and they simple to use
Posted on Mar 24, 2009
Anonymous
SOURCE: Cannot install driver (code 10 )
don't use the camera to load the pictures. see if your printer or computer have an SD card reader or buy one for $10 plug it into your USB drive and access the pictures that way...
Once you plug in your SD card Via SD card reader go to my computer and open the drive with the SD card on it... Shouldn't be difficult to figure out. Cut or Copy all your pics and paste them into your My Pics folder or any other folder of your choosing. Enjoy your pics...
Posted on Jun 25, 2009
Kaeleigh
  • 304 Answers
SOURCE: Whenever I turn on my
Hi, when ever I've seen that message it means the camera wasn't properly sealed when it was taken underwater. There isn't a way to fix that unfortunately you'll have to get a new camera and in the future make sure everything is sealed up tight before taking it in water.
Posted on Jul 03, 2011
How do I copy pictures from my camera to computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 18, 2013 | Olympus ? Tough 3000 / Stylus Tough 3000...
Can't upload video from camera to pc Olympus TOUGH TG-310 Digital Camera
Do you have Windows Live Photo Gallery? It comes with Windows 7, but if not you can download it here: http://windows.microsoft.com/en-US/windows-live/photo-gallery-get-started
  1. Open Windows Live Photo Gallery
  2. Connect your camera
  3. Click the Import icon in the top left corner.
  4. Select your Olympus and click import. It should import both photos and videos.
You can also try and select the videos you want using the file download module Windows displays when a new device is plugged in. If that doesn't work, try
  1. Start > Computer > Olympus Tough TG-310
  2. Then open the folders until you find the videos you want. Select them and copy them to your desktop (or any other preferred location).
I have had video issues with my Olympus TOUGH (could not delete them from the camera) which turned out to be a formatting problem with the memory card.
Aug 16, 2012 | Olympus TOUGH TG-310 Digital Camera
Olympus stylus tough 3000 digital camera my screen is white
Sound like a CCD sensoir problem, this job will need solve in the repait shop.
Jun 17, 2012 | Olympus ? Tough 3000 / Stylus Tough 3000...
I cannot get my camera to upload pic tomy computer
Having gone over a month without a response to my query, I assume my suggestion to use a card reader solved the problem.
Jun 17, 2011 | Olympus ? Tough 3000 / Stylus Tough 3000...
I have a new Olympus Stylus Tough-3000. Half of my vacation pictures have disappeared. When viewing the pictures there is a frame called "Picture Error" . I had viewed the pictures...
You can use a card reader to try to download them to your computer. You could also take the card to a store like Walmart and use one of their picture making machines.
Feb 27, 2011 | Olympus ? Tough 3000 / Stylus Tough 3000...
Hi, We gave my mum a new tough 3000 Olympus camera and we are unable to download the photos from the camera onto her pc. We have plugged the cord into both the USB port and the camera but nothing...
Hi Fiona
When you connect the camera to your computer with a usb cable if you click on 'start' at the bottom left of your screen and the click 'my computer' .
The window that opens will show all the drives connected to you computer eg your hard drive (usually c: ) and your cd/dvd . If you open the other drives one will have all the pictures in .
Then just select them all by selecting 'edit' then 'select all' at the top left of the open window and then click 'edit' and 'cut '.
If you then open My documents and open the folder 'my pictures' ,then click 'edit' and then 'paste' at the top left of the window all your pictures will be copied to that folder.
Just to make it easier the camera will have come with a cd ,if you put that in the cd drive it will offer to install software ,if you accept and install it every time you plug the camera into the computer it will start the program and copy the pictures automatically.
Hope this helped
Alistair
Jan 11, 2011 | Olympus ? Tough 3000 / Stylus Tough 3000...
Hi, how do you take black and white pictures on the Olympus µ Tough 3000 ?
you can't shoot in black and white but you can take a picture and change it to black and white.after taking your picture use the color edit option at playback.arrow right or left to choose the picture then press the ok button.use the right and left arows again to select desired color and press the ok button again.this will save a seperate image copy of you original only in black and white.
hope this helps.
Jan 09, 2011 | Olympus ? Tough 3000 / Stylus Tough 3000...
Is there any way to download images from an Olympus stylus tough 6000 to a flash drive or external hard drive without using a computer?
You can download images to a personal photo backup device such as an Epson P5000 (which is essentially a screen, batteries, hard drive, and just enough computer to transfer the pictures).
In general, the answer is no. The camera doesn't contain enough circuitry to do this, and neither do flash drives or most external hard drives.
If you need to back up your photos while traveling and don't want to carry a laptop computer, make sure you have adequate memory cards. And if you can find an internet cafe, you may be able to burn the pics to a CD/DVD and/or upload them to an internet site.
Feb 24, 2010 | Olympus Stylus Tough6000 Protective Clear...
Cameras Logo
130 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
