2007 Mercedes-Benz S550 Sedan Logo
timothy terrell Posted on Mar 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Driver window stuck on 2007 mercedes s550 - 2007 Mercedes-Benz S550 Sedan
Dave King
Level 3:
  • Master 1,606 Answers
  • Posted on Jun 06, 2013
Dave King
Master
Level 3:
Answers
1606
Questions
0
Helped
503843
Points
4860
This is either your switch module or the window servo. The servo\'s tend to be reliable where as the switches are an annoying re-occuring thing. The design of the switches internally is not that great and the drivers switch wears out first as it gets used most. Usually the front passenger side s never far behind. If the window was getting stuck then working or it seemed to work when you really pressed hard on the switch then that is your root cuase.
4 Related Answers
Anonymous
  • Posted on Aug 19, 2011
SOURCE: Where are the fuse boxes located on 2007 Mercedes
one box is to the right of the glove box behind a false panel and the other is behind a panel located behind the armrest in the middle of the back seat.
Anonymous
  • 720 Answers
  • Posted on Nov 13, 2009
SOURCE: what is esp on a mercedes 2007 s550
Could it be, your vehicle has Psychic intuition? Just kidding... :-)
Well, actually...it's not far from it !!!
ESP was co-developed between Daimler-Benz & Bosch, and was later adopted by Mercedes (across their range) from 1999.
As you know, most vehicles now have ABS braking...and some now have a form of Traction control.
Well, ESP exceeds the safety boundaries:
It's an intuitive system, connected to your vehicle's ABS, steering, dampers and Drive-train management.
ESP has saved countless lives since its implementation by reducing the risk of skidding on cornering and by maintaining the vehicle’s directional stability – even in critical conditions.
How exactly does it work?
1) This is achieved by selectively braking individual wheels, thus counteracting the tendency to skid in critical handling situations and allowing the driver to maintain control of the vehicle.
2) Oversteer is corrected by applying brake to the front outer wheel, understeer by applying brake to the rear inner wheel. Engine power can also be limited in some applications
3) The system can measure steering angles, lateral forces, and can compensate the damper ride height (optional).
Hope this helps....
** If this has helped you, please rate this solution **
Anonymous
  • 10515 Answers
  • Posted on Jan 11, 2011
SOURCE: 2007 mercedes s550 turn key nothing happen new
Do you have another key?
If yes, try with another key.
If the same problem persists with the new key, its unlikely to be a key issue. The starter system is fairly complex & needs diagnosing on a diagnostic tool such as Mercedes STAR diagnosis.
The EIS (Electronic Ignition Switch) reads the key information & sends a signal to the engine ECU to start (assuming it recognizes the correct key), the ECU then sends a signal to the starter to start the engine. The problem could be anywhere in between these components.
The EIS is a fairly common part for failure but this needs to be checked for fault codes & actual value readings to check the status of the switch.
I would take it back to the dealer for them to investigate as soon as possible as there is a chance it could fail completely leaving you in a stranded situation.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Anonymous
  • 3 Answers
  • Posted on Mar 10, 2011
SOURCE: How to reset c service on 2007 Mercedes s550
only dealer can reset or a regular auto shop that has a code reader.
How do i deactivate the sbc control on a 2007 s550 mercedes benz
as far as i am aware you will have to take to a dealer or some where that has the equipment to turn it off its not really a diy job if any light come on there is a problem with that system abs srs lights all need resetting
LOCATION OF FUEL PUMP RELAY ON 2007 MERCEDES S550
there should be 2 or 3 similar relays in a cluster either near the firewall or the upper shock tower on the drivers side of the engine area.. one should be the relay you need..the dealer can confirm the spot..
1helpful
My mercedes s550 cd player scans cd then says dics error
same with my problem .it's mean the eye laser is bad. you can't fix it.i have to go to the ebay buy the use one for $800 dollars. mercedes s550 tech such...too many problem. my is 65.000 mile i already replace lower arms control on 2 side A/C blower fan 2 struts suspension. now is the font lelf window not working. my god. i think the old toyota corola the tech is better then. (S550)
Driver's window does not work
connection or switch not working. may have to remove door panal to fix...good luck and hope this helps....Please rate my post.
How to replace a taillight bulb on a S550 Mercedes?
how to change tail lights on 2007 Mercedes benz s550
1helpful
Where are the fuse boxes located on 2007 Mercedes S550
1helpful
2answers
2helpful
3answers
Fuse location on Mercedes Sprinter 312D 1999
Mercedes Benz S550 problem with taking park and wont turn on
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
