Question about Reddy Heater-30-55,000 BTU Variable
I have a 35,000 btu Reddy heater that won't fire at the spark plug but is getting a signal from the magneto. Is the magneto bad or does the spark plug have to be in the mist of kerosene to spark?
I haven't used the unit in probably around 2 years but I emptied the tank and added new kerosene. The kerosene is squirting.
Posted by reichlenickg on
  • reichlenickg
    reichlenickg Mar 07, 2013
    I know that the unit is getting spark from the magneto but maybe it is not strong enough? I felt it spark when I touched the spark plug cable. I also checked the gap and tried another spark plug.
Reel Strong
    Habit-Forming:
    New Friend:
  • 74 Answers
  1. The FIRST STEP in diagnosing any heater problem should be checking the output of the air pump. Determine the air pressure required for the heater model that is being tuned. The air pump, in turn, is responsible for fuel delivery.
  2. If you do not know the required pressure look for a decal on the side (usually) of your heater. This decal will state the model number, serial number, fuel capacity, pump pressure, etc.
  3. If your plastic end cover looks like this......
I have a 35,000 btu Reddy heater that won't fi - m29609t.jpgM29609 has 2 threaded holes. The hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water.
or
If your plastic end cover looks like this.....I have a 35,000 btu Reddy heater that won't fi - m16545t.jpgmg src="/uploads/images/m16545t.jpg" alt="m16545t.jpg" class="h_mi" />M16545 has 2 threaded holes. The shorter projection with a hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water.
4. The other hole (longer projection) has a screw with a hole which adjusts a ball and spring relief valve assembly. Carefully adjust the screw until the gauge is reading the pressure level that is specified on the heater's label. If operating properly, the pump should produce more pressure than is required to operate the heater. The relief valve allows the excess air to escape before being sent to the nozzle.
5. Replace plug. Test for leak.
6. If you are unable to reach the desired pressure spray soapy water around the seal of the end cover- at the same time check the plastic cover for a crack. A cracked end cover will not allow the heater to perform properly and will not allow for an accurate reading. The pump must be set at the specified pressure in order to have adequate fuel delivery an adequate fuel atomization. Replace if needed.
7. If you set the pressure to specs and the heater does not perform properly or the cone does not glow a soft red, then check for other fuel delivery problems such as a clogged fuel filter, cracked rubber hose, clogged or worn nozzle, or a cracked nozzle adapter. Soapy water lightly sprayed in these areas will quickly identify the problem most of the time. Any air leak will create problems.
Posted on Mar 04, 2015
2 Related Answers
Anonymous
SOURCE: I have a Reddy Heater 35,000 BTU kerosene heater.
replace the rotor 1/2 inch thick
Posted on Mar 24, 2009
Anonymous
  • 188 Answers
SOURCE: 150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Posted on Jan 28, 2010
Have fuel but no spark at the spark plug 35000 btu
The electrodes might need cleaned. I am attaching a link, please check out the FAQ section, then scroll down and click on FAQ for spark plug heaters. I hope this helps. Reddy Heater Parts Sales Online Mr Reddy Heater Parts Master Heater Parts...
Jan 21, 2018 | Reddy Heating & Cooling
Problem: Will not spray fuel through nozze. Lines are not clogged. Have cheecked spark plug. It is firing. Special note: It is Series 35,000 Reddy Heater.
You can try adjusting the pump pressures, but it does sound more like the pump went out on you. Have you checked to see that the shaft to the pump is turning? I am not sure how that mates up with the motor be it a set screw, or coupling, but would check it over the pumps are generally not an issue.
Dec 20, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
REDDY HEATER 40,000 BTU KEROSENE&DIESEL
Clean your nozzel, check your fuel & air lines, you may need to replace Spark plug and filters. You can go to the manufacturers website at www.desatech.com and they offer service manuals. I hope this helps you!
Jan 23, 2010 | Reddy R60A Utility Heater
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater 35,000 torpedo heater
unit needs photo cell,or cell is dirty.to check photo cell disconnect the two blue wires from reset switch nad put a wire between where the blue wires were connected.that takes the photo cell out of system.fire unit up.if it stays running photo cell is bad,change it and all will be right again
Jan 27, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater Doesn't fully ignite
First thing I would do is clean all of your air and fuel filters and check your lines for breaks. A lot of times they will do that if your not getting enough air to fuel mix. If it continues after that it's the CAD/ flame sensor which you can get from MR. Heater for 3 bucks they are all basically the same and I know reddy heater wants 18 for the same thing.
Jan 27, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-30-55,000 BTU Variable Logo
169 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
