hey, you may follow the below steps:
Steps to Fix/Resolve/troubleshoot the error code 0xE000003D:
1 - Repair your Office app
Error Code 0xE000003D will be fixed when Office repair tool replaces all the corrupted system files. Follow the steps below to run repair tool to fix the error.
- Open Control Panel using Start.
- Click on Programs and select Programs and Features.
- Click on the Office product that you want to repair.
- Click Change.
- Select Quick Repair and click on Repair. If Quick Repair didn't fix the Error Code 0xE000003D, select Online Repair and click on Repair.
Note: If Office Repair did not fix this error code, then remove and reinstall the Office installation to fix this Error Code 0xE000003D.
2 - Steps to remove Office
In case if the error persists even after running Office repair tool, uninstall Office from your computer.
- Select Office Suite and click on Remove.
Note: If Office installation failed or it didn't fix the error, a manual installation is required to completely remove the Office Suite.
3 - Steps to remove Office manually to fix the Error Code 0xE000003D
If the
error code 0xE000003D is re-occurring, proceed with the following steps to manually remove Office program from your computer.
Step 1: Remove the Windows Installer packages
- Find the Office 16 installation folder, typically located in C:\Program Files\.
- Right-click the Microsoft Office 16 folder and select Delete.
Step 2: Remove the Office scheduled tasks
- Open a Command Prompt window as an administrator.
- At the command prompt, type the following commands and press Enter after each one:
schtasks.exe /delete /tn "\Microsoft\Office\Office Automatic Updates"
schtasks.exe /delete /tn "\Microsoft\Office\Office Subscription Maintenance"
schtasks.exe /delete /tn "\Microsoft\Office\Office Click To Run Service Monitor"
Step 3: Use Task Manager to end the Click-to-Run tasks
- Open Task Manager.
- Click the Process tab
- If the following processes are running, right-click each one, and then click End task after you select each process.
Step 4: Delete the Office files
- Press Windows logo key + R to open the Run dialog box.
- In the Open box, type %ProgramFiles%, and then click OK.
- Delete the "Microsoft Office 16" folder.
- Delete the "Microsoft Office" folder.
- Open the Run dialog box, type %ProgramFiles(x86)%, and then click OK.
Step 5: Delete the Office registry sub keys
- Open Registry Editor.
- Delete the following registry sub keys:
- HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\ClickToRun
- HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\AppVISV
- HKEY_CURRENT_USER\Software\Microsoft\Office
- Then Delete the Office key.
Step 6: Delete the Start menu shortcuts
- Type %ALLUSERSPROFILE%\Microsoft\Windows\Start Menu\Programs, and then press Enter.
- Delete the "Microsoft Office 2016 Tools" folder.
4 - Download and install Office
1. Sign in to your
My Account page using the link
https://go.microsoft.com/fwlink/p/?LinkId=613327
2. Choose
Install.
3. Click
Run or the equivalent depending on the browser you're using.
4. When you see "You're good to go", click
All done.
Error Code 0xE000003D for Microsoft Office Outlook and Windows Updates
