My 910 is simply stopped. Light on it but no picture. Just read about reset button but do not where it is
Before you reset your 910, first make sure your battery is (well) charged and if you are using an SD card, it is taken out.
The reset button is actually a tiny hole at the bottom / base of the unit.
Simply use a straightened out paper clip or something similar, insert it into the hole and hold it there for 20 seconds or so, until the device turns off. Then push the ON/OFF button and hold it down for a while ... (5 seconds ... or lots more) until the device powers up again. If you're using an SD card, you can then insert the card (when it is looking for it).
SOURCE: 910
HERE IT IS: http://www.tomtom.com/support/product.php?ID=232&Language=5&FID=6971#reset_button
SOURCE: Tom Tom 910 Green light but does not come on.
Remove battery and disconnect from power for 5 minutes, also remove map card, this will reset the device. Try it out
click;
Repair4GPS: How to Clean, Upgrade, Repair, Mod, Disassemble a GPS ...
see here
http://www.tomtom.com/lib/doc/legal/lw/LW-English-US%20CAN.pdf
To only way you can fix it is taking apart the Tom Tom, checking if the flat ribbon cable and connector to the screen are well in place and eventually replace the display ($80 on Ebay).
Unfortunately this will invalidate the guaranty, and you risk to damage your GPS if you are not a really experienced DIYer. Tom Tom offer one year full guaranty on all their receivers.
Contact Tom Tom and get it repaired:
Support URL: http://www.tomtom.com
Support Phone Number: 978.287.9555
Support Email Address: [email protected]
Hope this may help;
DON'T FORGET TO RATE:
SOURCE: how to reset tom tom 910
the reset hole is hard to find... If you are looking at the back of the unit, it is in the upper right hand side of the liitle plastic protrusion at the top of the semi-circular opening above where you can see the exposed circuit board.
SOURCE: 910 wont turn on,green light comes on in cradle or
Hi i have had the same problem with mine, its a problem with the start up files, plug it in to the pc and also the wall charger, it should then recognise it and then ask to scan and fix the problems once it does that its all fixed, cheers
SOURCE: tomtom 910 not switching on
A hard reset is done by pushing a paperclip into the reset hole on the bottom.
