Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
I have a sony 60in that clicks when I turn on
Posted by michael on
Justin S
    New Friend:
  • 16 Answers
Anything else? Red lights? Need additional info.
Posted on Nov 04, 2013
Multiple blue spots on the sony Grand WEGA KDF-60655 60in TV
Indicates for model shown a bad optical light engine---check with Sony as several models this is covered even if the set is out of warranty (CLASS ACTION LAWSUITS GOT THIS).
It is the most expensive part in the set not even of course counting labor to replace it.
Mar 18, 2012 | Sony Grand WEGA KDF-60WF655 60" Rear...
Hi my 60in sony Wega has a problem...when i turn it on its all good...then after 10 sec? it turns Off...then the red light flashers 4 times...Can you please help
kadprint,
Have you had any problems with the display lately, such as color bleed, blue dots, or other anomalities or non standard behavior? If you have chances are you have a bad optical unit. Sony had a problem with their TFT panels throughout the past ten years. Your model is one of the unfortunate units to experience the problem. Unfortunately any remeidies are long gone. Here is an excellent website which will explain the problem and perhaps what your remedies may be.
http://sites.google.com/site/sonylcdrptvproblems/#TOC-Self-repair
Thanks for using FixYa and for the great repair.
hardrocko
Dec 09, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
60in Sony KDS-60A2020 LCD rear projection picture goes on and off
yes replace the lamp, sony units have certain specs that the lamp must meet to operate correctly. If the Lamp you purchased is made by LTI, these lamps do not last long as they are poorly manufactured. Look at the bulb and see who is the maker if its says LTI then replace with a Phillips brand that meets spec's for sony.
Jan 30, 2010 | Sony KDS-60A2020 60" HDTV
My Sony 60in Wega Rear Projection is going dark every few minutes and the sound goes out. Can't find the owner's manual. What do I do?
Your suspect is the lamp. You will need part number A-1085-447-A....If the lamp fails to light or goes out, so will the sound.
Nov 11, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
In the lower right hand corner of the screen on my sony grand wega 60in lcd tv there is a blue haze about 4in by 4in trianguler in shape working its way toward the center. what's up?
You have a Optical Block that is bad. I would call Sony at 1800-222-SONY and see if the would assist you in the cost of the repairs.
Hope this helps,
Skyassoc
Jul 22, 2009 | Televison & Video
Blue screen on 60in
Sharpness between 10 and 20 seems to fix every problem in that area have you try ed that
May 06, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Mar 10, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Open Questions:
See all Sony Grand WEGA KDF-60XBR950 60" Rear Projection Questions
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
