Question about Broderbund PrintMaster Platinum 16
Will printmaster platinum 16 run on windows 8
Printmaster not running on windows 8
Posted by Ludger Lehmann on
Anonymous
Thank you for your sharing and i would like to share my experience with you, i got a good windows last week, it is genuine and cheap, https://www.facebook.com/Office-2011-for-MAC-Key-1799093256986418, posts which cost me a little money and works well now, you can find all relevant keys there, strongly recommend it to you, the customer service is quiet well.
Posted on Jun 01, 2016
Anonymous
Thanks guy! It's helpful! And friends you can also get your windows 8.1 upgraded from http://windowkeydownload.blogspot.kr/2016/05/how-to-get-windows-7-for-free.html. It's convenient and easy to finish the upgrade process with this site.
Posted on May 31, 2016
Gary Harold
    New Friend:
    Problem Solver:
  • 8 Answers
Activate windows click here: www.acyberkey.com
you can find the keys you want in a low price that you have never imagined.
Posted on Mar 10, 2016
Letitia Deleon
    New Friend:
  • 3 Answers
It seems there is some problem, so listening to a friend's introduction to: https://www.facebook.com/Windows-81-Product-Key-389779677882215, to my surprise,I spent very little money and work together well.
Posted on Oct 09, 2015
2 Related Answers
Anonymous
  • 154 Answers
SOURCE: can I run Printmaster Platinum 16 with windows
Yes you can !!!
The Windows® Vista2_bing.gif Program Compatibility Wizard can allow older programs that were not designed for use with Windows® Vista to run on Windows® Vista.
The Program Compatibility Wizard prompts you to test the program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows® XP2_bing.gif, set the compatibility mode to Windows® XP and try running the program again. If successful, the program will start in that mode each time. The wizard also allows the use of different settings, such as switching the display to 256 colors and the screen resolution to 640 x 480 pixels.
To run the Program Compatibility Wizard, complete the steps below:
  1. Close all programs and windows and return to the desktop.
  2. Click the Start button on the Windows® taskbar. The Start Menu will appear.
  3. Click on Control Panel. The Control Panel window will appear.
  4. Click on Programs. Additional program options will display.
  5. In the Programs and Features section click the link Use An Older Program With This Version of Windows. The Program Compatibility Wizard will launch.
  6. Click Next to Continue.
  7. Click the “I want to choose from a list of programs” radio2_bing.gif button and click Next. A list of programs will display.
  8. Select the program that is to run in a Compatibility Mode and click Next to continue. A list of Compatibility Modes will display.
  9. Click the radio button next to the desired Compatibility Mode and click Next. A list of display settings will display.
    NOTE: These display settings are not available options in Windows® Vista. They are only available when running a program in Program Compatibility Mode. The only reason to choose either of these settings is if you are experiencing difficulty installing or running an older application designed to run in Windows® 95, Windows® ME or Windows® 98. If all options remain unchecked, then the current Colors and Screen Resolution settings will not be altered.
    By default, Windows® Vista uses visual themes that may change the appearance or behavior of other programs, especially those games or educational programs that include intensive graphics and animation. To prevent the visual themes from affecting these programs, check Disable Visual Themes.
  10. Choose the desired display settings and click Next to continue. Administrator privilege options will display.
  11. Choose the desired administrator privilege setting and click Next to continue. A Test Your Compatibility Settings window will display.
  12. Verify that the settings are correct. And click Next to continue.
    NOTE: If the settings are not correct, click the Back button to return to the previous screen (or screens) and make the necessary changes.
  13. With the correct settings selected and showing in the "Test Your Compatibility Settings" window, click Next. The selected program will launch.
  14. Run the program to test the settings.
  15. After testing the settings, or close the program to return to the Program Compatibility Wizard.
    NOTE: After the program is closed, a window with the question "Did the program work correctly?" will appear. The "Yes. Set this program to always use these compatibility settings" will be selected.
  16. If the program functioned properly using the compatibility mode that was selected above click Next. The Program Compatibility Data window will open.
    NOTE: If the program did not function correctly, click "No, try different compatibility settings" and complete the Wizard. After completing the wizard, try the program again.
  17. Choose Yes or Now and click Next to continue. The Completing the Program Compatibility Wizard window will appear. Click Finish to close the window.
  18. Launch and use the program.
NOTE: If you have questions regarding the Program Compatibility Wizard or Windows® Vista (or both), contact Microsoft®, or go to http://www.microsoft.com for additional information
Posted on Apr 01, 2010
yaoyang
  • 2340 Answers
SOURCE: will Printmaster Platinum 16 run on windows 7 I
Printmaster Platinum 16 is not compatible with Vista or windows 7.
Posted on Oct 24, 2010
Unable to download from disc Printmaster v.18.1 despite being led to believe its compatible with Windows 8
Printmaster 18.1 is not really compatible with Windows 8. Here's a link to a possible solution directly from Broderbund. You can try it, but you might be out of luck.
Printmaster 18 1 Platinum
Feb 28, 2014 | Mindscape PrintMaster Premier 7.0
PRINTMASTER THAT WILL RUN ON WINDOW 8
https://www.microsoft.com/en-us/windows/compatibility/CompatCenter/ProductDetailsViewer?Name=PrintMaster%20Gold&vendor=Encore&Locale=1033&ModelOrVersion=18&BreadCrumbPath=PrintMaster&Type=Software&tempOsid=Windows%208
Oct 25, 2013 | Computers & Internet
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
Our business has been using Printmaster 15 for a few years now. We recently bought a new computer with windows 7. Printmaster 15 is obviously not compatible with Windows 7. I bought printmaster 2011...
You can try version 15 in compatibility mode:
Troubleshoot Compatibility
This can help with some (but not all) programs/drivers:
1) Uninstall the program if it's already installed. Then when you install/reinstall it instead of double clicking on the install file right click it and select "Troubleshoot Compatibility"
2) Then click "Try Recommended Settings" and in the next window click "Start the Program" to install it.
3) After it installs see if it works correctly. Please note - some programs may not be able to run in Windows 7.
More details about how to make older programs run in this version of Windows:
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
Jul 19, 2017 | Broderbund PrintMaster Platinum 16
Can't install PrintMaster Platinum 16 on my Windows 7 PC
This version of print master is not compatible with windows 7.
see the compatibility criteria of Printmaster on the link given below!
http://www.microsoft.com/Windows/compatibility/windows-7/en-us/Details.aspx?type=Software&p=PrintMaster%20Platinum&v=Encore&uid=18&l=en&pf=0&pi=9&c=Graphics%20%26%20Printing&sc=Image%20Editing&os=64-bit
You can try if this works in compatibility mode in your pc - Try running in compatibility mode. Right click the program icon, click Troubleshoot Compatibility, wait while the problem is detected. Click Troubleshoot program > select an appropriate version of Windows the program is known to run in, try Windows Vista SP2 > start the program to see if it runs. If it runs, click next to proceed with saving the settings for it.
Mar 19, 2011 | Encore PrintMaster 17 Gold for PC
I have windows 7 and printmaster 7.0 is not working, what do I do?
Hello Patrick,
Try running Printmaster in Windows XP compatibility mode.
1. Right click on the printmaster icon. A pop-up menu would appear. 2. Select 'Properties.' 3. Select the 'Compatibility' Tab. 4. Note the first check box. It says "Run this program in compatibility mode for:" 5. Select 'Windows XP (Service Pack 2)' or 'Windows XP (Service Pack 3)'
If this doesn't work, the problem may be with your installation...
Feb 25, 2011 | Mindscape PrintMaster Premier 7.0
Will Printmaster Platinum 16 run on windows 7 I
Oct 24, 2010 | Broderbund PrintMaster Platinum 16
Printmaster and Windows Vista
been running printmaster platinum 8.0 for many years on several different computers . have had it installed and running on my HPPavilion slimline for two years now . problem is that i cant get it too print anything new that i create it will print out older stuff that i have created but nothing new . have checked drivers on print they are all up to snuff , and have uninstalled and reinstalled both the printer and the printmaster program but still cant get it too print anything new that i create . it does print everything else in the PM program. and otherwheres on my computer
Feb 09, 2008 | Broderbund PrintMaster Platinum 16
Computers & Internet Logo
1,158 people viewed this question
Top Broderbund Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
