Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
Turn off vacation mode
SOURCE: rheem power vent motor doesn't shut off
There could be blockage in your water heaters venting on the outside of the home. It sound like the high limit switch has been tripped. Try unplugging the tank and plugging it back in. this will reset the tank. if the problem persists you will want to call your provider for service.
Posted on Jul 29, 2010
SOURCE: I have a 2 year
The flame sensor is bad....and it is not sensing that the flame has lit....
Some models have a separate flame sensor and some use the ignitor to sense the flame...
If it has a separate sensor then clean it with a soft cloth... if it is the ignitor then the ignitor is bad...
heatman101
Posted on Nov 25, 2010
SOURCE: Rheem Power Vent 50 gas water heater will not come
Water inside tank-type water heater can remain hot for some time.
That's one advantage of well-insulated tank-type water heaters.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Power outage can be related to failure of gas control.
Unplug stuff when power goes out. And then plug back in after power is restored.
Water heaters with electronics are not protected from surge.
Electronics can blow out during and after power outage. For example nearby lightning strike will cause current to run along household wires. With ordinary power outage, once power is restored, the surge can affect all kinds of electronic circuitry such as timers, water heaters, water softener, treadmill etc.
Sounds like you have intellivent gas control valve:
Open following link to identify gas control, and download typical manual, and download intellivent service manual with troubleshooting, error codes, etc.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Aug 27, 2011
Testimonial: "Thank You for your help geno_3245"
Jul 17, 2014 | Rheem 42PV75FW Power Vent Heavy Duty...
Aug 12, 2013 | Water Heaters
May 28, 2013 | Water Heaters
Oct 09, 2012 | Water Heaters
Sep 10, 2011 | Rheem Water Heaters
Aug 26, 2011 | RHEEM 50 Gallon FVR NATGAS Water Heater...
Aug 18, 2011 | Rheem 50 GAL FVR Propane Gas Water Heater...
Nov 25, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Apr 06, 2010 | Water Heaters
Aug 21, 2009 | Rheem Water Heaters
96 people viewed this question
