Question about Mag Innovision Computers & Internet
I need a driver for a mag innovision model 778 monitor
I can plug it into my laptop and it will come on no problem
5 Related Answers
Anonymous
  • 198 Answers
SOURCE: Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
Anonymous
  • 50 Answers
SOURCE: need driver and users manual for mag innovision lt576c monitor
Download updated drivers and manual from Mag website link here: http://www.maginnovision.com/Support/Downloads.aspx where you select product group, type and model.
Posted on May 25, 2008
shaggyrat
Christophe Thompson
  • 1224 Answers
SOURCE: need a driver and users manual for mag innovisionLT576s
42905439-177x150-0-0_.jpg ViewSonic (HASU05F) Information: Product details Price Range: $25.00 - $40.00 at 3 stores This AC Adapter is ideal for use with your Flat Panel Monitor or LCD Display. The High performance AC Power Adapter pictured here provides consistent and continuous power at the specified Voltage and more
this is what else u need to power the monitor it is plug and play compatible
make sure your video card has the right software to run monitor
Where can I get drivers for my video cards?
Answer ATI – http://www.atitech.com/
Nvidia - http://www.nvidia.com/
Matrox – http://www.matrox.com/
Pinnacle – http://www.tridentmicro.com/
Trident - http://www.tridentmicro.com/
Diamond Multimedia – http://www.diamondmm.com/
Cirrus Logic - http://www.cirrus.com/en/
http://www.opendrivers.com/driver/214283/mag-lcd-monitor-drivers-windows-95-98-2000-xp-me-nt-free-download.html
heres the driver that you needed for your monitor
I can’t find where the AC power cord plugs in on the back of the monitor. Answer There are two places where the AC connector could be found.
1. Look at the back of the monitor right next to the signal cable connection.
2. If the signal cable does not detach from the monitor, follow the signal cable to the end, and you will see the 15 pin D-Sub connector (blue connector). There you will find a small hole with a pin inside (in between the two notches).
Posted on May 26, 2008
Anonymous
  • 186 Answers
SOURCE: i need driver monitor mag innovision for install
Chek Ur OS and download drivers from here :
http://list.driverguide.com/list/company621/
Posted on May 16, 2009
Anonymous
  • 466 Answers
SOURCE: mag innovision 786n winxp driver download
DriverGuide.com claims that the driver is available here
http://members.driverguide.com/driver/detail.php?driverid=489569
for US$2,99.
There is an "universal driver" also here:
http://www.edriverdownload.com/driver/MAG%20InnoVision%20/MAG%20InnoVision%20all%20crt%20models%20Driver.html
Posted on Oct 22, 2009
I am unable to get MAG Innovision 14" LCD monitor
You need laptop-type 12V, 2.5A (minimum) adapter plugged into back of VGA plug
4helpful
MAG LT765s monitor, model 780; where do i plug in adapter
Sometimes the power adapters on flat screens face the floor. So, if you look under the screen under the stand, you will likely see the plug.
5helpful
I bought a mag innovision model 780 monitor at a garage sale to use with my ACER mini laptop. This monitor has a manufacture date of January 2003 - it did not come with a power supply. Where is the power...
With Most Mag monitors, the plug is a simple 3 prong on the bottom side of the monitor. Though it isn't proprietary, it isn't a common power plug either. Radio Shack does carry this type of cord. Just look on the bottom side of the monitor itself. the three round plug "thingy" is where the 110v plugs in straight from the wall. Best of Luck!
1helpful
On my Mag Innovision model 700 P lcd monitor, the integrated right side speaker does not produce any sound. In XP control panel I do have both left & right speaker set to max.
On the plug to the computer sound card, is the plug completely inserted? The end of the jack is for Left channel and the right channel is only fed if the plug is fully inserted.
3helpful
Mag innovision 786n winxp driver download
for US$2,99.
1helpful
I have a MAG INNOVISION LT765s LCD monitor. When the computer boots up, the power button on the monitor won't stay on so the display won't come on. It sometimes takes an hour of fooling around with the...
I have had similar problems with my Mag LCD monitor. I recently dicovered that the problem was with the adapter and not the monitor. Try replacing the power adapter.
Need driver and users manual for mag innovision lt576c monitor
3answers
Computers & Internet Logo
Top Mag Innovision Computers & Internet Experts
Ekse
Mandeep  Singh
Mandeep Singh
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
