Question about Stihl Ts 410 420 Cut Off Saw Decompression Grommet
I have worked for months working with a ts410 stihl saw using the correct mixture , and yet the pistons are damaged ?????? is there any other way they can be damaged
SOURCE: hi,my stihl ts 410 saw
Sounds like an overheating problem.
Are you working in a well-ventilated area or in direct sunlight?
Check, if you can, the temperature of the motor case.
You might have to take a break more often.
This hot summer has stressed a lot of motors and electronics.
When it shuts off you know it is trying to save itself from burnout.
Posted on Aug 29, 2011
if this machine ran ok before this problem,and no one has adjusted the carb,then i would check the crank seals.i have just had this problem.and it was the seal on the puller side,though i replaced both whilst i was at it.hope this helps my freind.
Posted on Jan 30, 2012
SOURCE: stihl ts 350 super cut saw died in the middle of cutting a brick
i am doing one right now (ts350). I had no spark. 2 problems there. I had to replace on/off switch do to dust making it malfunction. still no spark so I had to replace the Ign. module. got great spark now. It's not cheap either ($226.00 canadian) had to order it from a dealer. Now I have no fuel getting to the cylinder so I have more work ahead of me. I hope this helps if you only have a no spark problem. It's about a 6 on the skill level.
Posted on Sep 21, 2012
Mar 17, 2016 | Stihl Saws
May 08, 2014 | Stihl Ts 410 420 Cut Off Saw...
Apr 13, 2014 | Stihl Ts 410 420 Cut Off Saw...
Dec 31, 2013 | Stihl Ts 410 420 Cut Off Saw...
Mar 31, 2013 | Stihl Ts410 & Ts420 Cylinder & Piston Kit
Mar 06, 2013 | Garden
Mar 23, 2012 | Stihl Ts 410 420 Cut Off Saw...
Dec 27, 2010 | Stihl Ts 410 420 Cut Off Saw...
Oct 27, 2010 | Stihl Ts 410 420 Cut Off Saw...
Jun 16, 2010 | Stihl Ts 410 420 Cut Off Saw...
53 people viewed this question
