How to record tv channel in mp4 format in jxd M500
Is it possible to record tv channel in mp4 format? JXD M500 always record tv channel in 3GP format I want to record the tv channel in mp4 format for better clarity.
2 Related Answers
Anonymous
SOURCE: Video not seen in JXD 661 MP4 player SD Card
convert the video into a format like mp4,3gp
Posted on Dec 27, 2009
Byron Narciso
  • 679 Answers
SOURCE: Sir, I Have JXD 656 recently I connected it to my
WARNING : This procedure can render your device dead, so do not try if your player is working fine.
  1. The most important step of the whole process is to correctly identify your device CONTROL CHIP and CPU, using wrong firmware or flashing tool may cause damage to your device, unscrew and open your device and write down all chip id's and motherboard numbers you see, you can also try the EasyChips - firmware identification utility but it did not worked for me.
  • You will now need to download the correct firmware and flashing utility for your device, visit sites below and search for your control chip and cpu to download the firmware and flashing utility, you can also post on user-forums to get help identifying the firmware :
  • In my case the chipset was Sunplus AJ262-V7 and the utility needed to flash it was FRM Pro.
  • Once identified you need to connect your device to computer via USB in camera mode (Press A + OK button and plugin USB cord on player), for Windows to identify this mode you will need camera drivers you need to point Windows Found New Hardware Wizard to Driver folder downloaded with the FRM Pro utility above, this will install the first camera driver, for correct identification by flashing utility you need to install a second camera driver - open Windows Hardware Manager and install unidentified camera device drivers by pointing the driver wizard to Driver folder used earlier.
  • Now install and launch FSM Pro flashing utility the new firmware.
  • Posted on Jan 13, 2011
    What is the difference between JXD S7800A and JXD S7800B?
    JXD S7800 has two versions:
    JXD S7800A: Quad Core, 1GHz (CPU:cortex A7, GPU:Power VR SGX 544 mp2),1GB DDR3, 9 emulator games and android games
    JXD S7800B: Quad Core 1.4GHz,2GB RAM, ARM Mali-400 MP4 GPU, 16 emulator games and android games
    JXD S7800B is better than 7800A.
    Dec 12, 2014 | Audio Players & Recorders
    Cannot switch on
    I think there should be a major problem in your jxd player. You should go to the manufacturer or seller with your jxd player. They can replace your jxd player or repair it without any cost if your player still have guarantee or warrantee.
    Mar 15, 2014 | Easy Brand JxD 661 2G 2.8 inch Mp4 player...
    My jxd 698mp4 does not play mp4 video format
    It is possible that the format is not correct and needs a recheck. Please try the same on another player or find the properties on your PC. If not reload with a conversion to another format and try to confirm the player..
    Mar 19, 2011 | Televison & Video
  • Jan 13, 2011 | Audio Players & Recorders
    JXD 656 IS NOT WORKING AND HANGS ON STARTING SCREEN
    I have Purchased a I POD JXD656 abut three months before. It runned but suddenly I formatted it with WINDOWS XP SETUP disc And suddenly with this format by software of MP4 get destroyed and it stopped working When It starts It Get hangs on JXD SCREEN If you can help me contatct me AT [email protected]
    Mar 30, 2010 | Audio Players & Recorders
    Dec 27, 2009 | Apple iPod touch
    I accidentally erased the flders that appear on the computer when i connect my mp4 how can i get the back in order for me to be able to use it again it's an MP4 Titain 4GB
    hello dear jxd Ltd
    here maynmar
    i want to say some question about jxd mp4 player
    it csreen is white screen and another jxd mp5 player is power green led is open but screen is black csreen so, pls explain me above problem
    Oct 15, 2009 | Audiovox MP4128 MP3 Player
    My JXD player JXD 631 cant support mp4 format
    download a 3GP converter and it will be ok
    Jun 28, 2009 | Audiovox MP4128 MP3 Player
    Cannot view vidoes in JXD 661
    i have problem with jxd661 it does't shows anything only green light is shown when i switch it on.....................
    May 31, 2008 | Audio Players & Recorders
    19 people viewed this question
    Muntejaya Ginting
    Muntejaya Ginting
     Grubhead
    Grubhead
