see this causes and fix it. God bless you
Water Inlet Valve
If the washer is overflowing and power is
shut off to the washer, the water inlet valve has failed. Replace it.
Pressure Switch
If the washer is overflowing the pressure
switch might be defective. The pressure switch is attached to a small
tube which is attached to the outer wash tub. As the water level rises
the air pressure in the tube increases, once the set water level is
reached the pressure switch turns off power to the water inlet valve.
Check to be sure the air tube to the pressure switch is clear before
replacing the switch.
Low Water Pressure from House Supply
If the washer is overflowing the water
pressure to the water inlet valve might be too low. The water inlet
valve requires a minimum of 20 psi to shut off properly. If the pressure
is lower, the valve may not close fully when the power is shut off.
This results in the valve leaking water into the washer and causing it
to overflow.
