Kenwood ka 996 integrated amp. The standby light will dont turn off. I also need to see if someone will tell how everything should be hooked up.
All kenwood. Integrated AV amp ka 996 Stereo power amp km 894 Stereo double cassette deck kx w894 AM FM stereo tuner kt 594 Multiple compact disk player dp r896 With the way I have it hooked up the km 894 amp does not kick in when I turn it on.
  • agullion Mar 07, 2013
    David Dunn. The integrated amp is what all the AV . On the kA 996. The stand by light does not turn off. And I'm curious if that is causing some of the problems. I have it all hooked up but the power amp does not kick in when turned on and is hooked to the integrated amp.
    Master:
  • 483 Answers
The standby light should be on if the unit is not 'ON' if you want the 894 to turn on when you power up the 996, then you will have to plug the ac for the 894 into the 'switched' ac outlet on the back of the 996
what specific problems do you have with this system
Posted on Mar 07, 2013
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Kenwood Stereo
I presume you realize none of these things produces speaker amplification. A receiver would do that and facilitate graceful and simultaneous interconnections. But it's not a necessity for selective interconnective between them, just not all at the same time.
I can't find any details on anything you named except the Tuner.
Typically, the tuner would use an RCA pair to go to a receiver AUX, TUNER or other Line Level input for source selection and amplification. Lacking a receiver, run it to the Tape Deck inputs for recording.
Ditto for the CD changer, but you'll probably have to disconnect the tuner.
Posted on Jan 27, 2010
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
Nov 15, 2016 | Kenwood Audio Players & Recorders
Where can I find a manual for Kenwood Tuner kt-57?
Is it a tuner only? If so you will need a power and or just a receiver with speakers. A tuner only has no power output for things like tvs.
Mar 25, 2016 | Kenwood KT-57 Stereo Synthesizer AM/FM...
Kenwood integrated amplifier ka 895. Why no sound output?
How do you get to know that the unit turns on .After power up what are sequences happening i can help you
May 26, 2015 | Kenwood Audio Players & Recorders
How do i get a free service manual download of a kenwood ka-127 model stereo integrated amplifier in any digital format?
I doubt you will be able to find a digital copy, and Kenwood dropped their home audio line 2+ decades ago. I probably have a hard copy of the manual, as I was a Kenwood Factory Service Center for over 25 years, however, it is not free. If you would like more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 11, 2014 | Audio Players & Recorders
I just got a Kenwood system, i would like to know how to hook it up, it has, Kenwood power amplifier km207, kenwood stereo control amplifier kc 207, disc player dp-m 97, cassette deck ky-77 cw, stereo...
That's a pretty standard setup. RCA cables from the KM207 to the preamp (KC207), and RCA cables from all of the other components into the KC207. Speakers connect into the KM207
Nov 01, 2012 | Master DE Kenwood with Housing...
Dead Kenwood Home stereo Amp. KA-2002
Some says it is only dead when it is buried.
Open it up and check, ( Be sure it is unplugged)
Only if you feel you can DIY or have a tech do it for you.
Oct 06, 2012 | Kenwood Vintage Model Ka-6006 Stereo...
Don't know how to hook up kenwood ka-994
Check the bellow link for the user manual of kenwood KA-994. In page number 4 of the user manual You can see how to make the connections to the receiver
Manual
Ajin
Mar 09, 2012 | Audio Players & Recorders
I have an old kenwood stereo system I forgot how to hook up it is a ka-87 amplifier a kt-57 tuner and a double deck cassette player kx-57w .Can anyone help?
Connect the RCA Outputs of the Tuner to the RCA inputs for Tuner on the amp.
Connect the output of the Tape Deck to the Tape Input on the amp.
Connect the input of the Tape Deck to the Tape Output on the amp.
Select Tuner on the amp to listen to the tuner.
Select tape Monitor to hear the Tape Deck(s).
Dec 30, 2010 | Audio Players & Recorders
768 people viewed this question
Ekse
 Grubhead
Grubhead
