This is a sony Vaio T Series Ultrabook, its like a normal laptop but with a touchscreen. I could move the mouse around but i can't click on anything with the left or right buttons.
SOURCE: the arrow is frozen on my laptop other than that the pc is working normally
Could be the mouse lock key. I am unsure as to which key it is on yours. Mine is the F9 key. it will have a picture of 2 mouse on , 1 with a no go sign over it (circle with a diagonal line through) try pressing the "fn" key and F9 and see if this unlocks the cursor.
SOURCE: Touchpad and buttons won't click on Sony Vaio
it could be caused because of hardware failure or software failure, in case of hard ware failure it would be best to call sony tech support but in case of software issue , if you remember the day it was working fine,
do a system restore to the date it was working fine, which will reset your software configuration to the date you know it was working ok, so if it was caused by software issue it will be resolved, but any programs that you installed after the restore date will be lost
to do system restore
reboot your system when you see the sony logo start tapping the F8 key and you will come to a menu here select safe mode and boot and then
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts select the bold date your system was working fine and continue as it guides,
If you think the information i gave you was helpfull please do rate me
Regards
Ltoso
SOURCE: my left mouse button on sony vaio vng-nw150j isn't working
Generally, if a mouse button quits working, it requires the replacement of the touchpad assembly.
Boot to the safe mode, see if the button works there, if it doesn't, then it is a failure of the switch in the button
http://cgi.ebay.com/TESTED-Sony-Vaio-VGN-NW150J-LCD-Keyboard-Palmrest_W0QQitemZ120522991092QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0fbae5f4#ht_1088wt_1165
SOURCE: My laptop left mouse button has stopped working
Common hardware problem. The correct solution is a replacement tracker pad and mouse, however you may be able to get the problem fixed by cleaning under the pad. Either way it requires taking the laptop apart.
WildeFalcon
SOURCE: sony vaio AR51E mouse cursor doers not move as
Go to Control Panel
SEE mouse icon... OPEN this
see if the touch pad is disabled
Try to go to the site Sony VAIO model specofic download latest driver for the touch pad
there are specific setting to enable the pad somehate it some love it but you can sort it out by looking at Control Panel /device manager etc
if USB mouse is working at least you can navigate to find issue
