Frigidaire Gallery GLEFZ384GC Kitchen Range Logo
carol martin Posted on Mar 06, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire es300 gas range kepps flashing f10 and f13.how to resetand get the clock working
  • Official Brand Answer 4,342 Answers
  • Posted on Mar 08, 2013
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1466583
Points
5907
Hello Carol Martin - Typically, error codes F10 and F13 could indicate a variety of issues. The range could possibly have a shorted keypad, runaway temperature (higher than normal temperature), faulty EOC (electronic oven control) or, display wire harness missing/not connected. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
5 Related Answers
A
Anonymous
  • Posted on Aug 25, 2008
SOURCE: frigidaire PLES3890
i wouldnt buy one of these products again never!!!!
Anonymous
  • Posted on Dec 24, 2008
SOURCE: Frigidaire Electric flat top Range
My range will not hold the heat for either the convection or regular heat. the model number is CGLEF385AS2
Anonymous
  • 3361 Answers
  • Posted on Mar 04, 2009
SOURCE: whenI try to bake or broil--get error msg. F13
Unplug the oven.
Wait 30 seconds and plug it back in.
If the code reappears you must replace the EOC.9electronic clock).
Anonymous
  • 725 Answers
  • Posted on Nov 18, 2009
SOURCE: I have a frigidaire gas range model # fgf337ecc
This is your electronic control board that has gone out. When you order yourparts through us, we provide part removal/installation instructions for our customers.
We also ship overnight and would love to get you cooking again real soon.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your brand and model number. Thanks, Ella
Anonymous
  • 506 Answers
  • Posted on Dec 15, 2009
SOURCE: we have a f10 error code on our electric range
F10 is thermal runaway. The RTD is most likely bad. Open the oven door and look in the upper corners you will see a little metal rod protruding from the back of the oven, this is the RTD or resistive temperature device. A local parts store should have these.
2answers
Have Frigidaire Gas oven FFGF3053LSF. We had a power surge & F13 code came on display. Power restored, clock works, F13 code is gone- but now a DR code comes on when I push bake or broil button
Exact same thing happened to me. After a power failure my Frigidaire stove worked and the clock worked but bake broil and self clean gave me a DR error. Tried everything to reset nothing worked. When I unplugged and plugged back in I got an f13 code.I changed the control board and the entire oven is back in business!c86f7aab-24e4-4403-bcd6-0b838d53ac57.jpeg
Flashing fault code F13
Check your oven sensor is what I would do. See if it reads 1100 ohms at room temp. If it is open or shorted it is bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Top and bottom heating element does not work on Frigidaire electric range ES300
Usually when both elements are not working and everything else is working fine, the problem is your OCU (oven control unit), commonly known to consumers as the clock.
The clock controls the oven and most times does not produce an error code when it fails.
You will need the actual model number from a sticker located on the oven frame when you open the bottom drawer, the sticker will have the model and serial number clearly listed.
Do a Google search for that model number and find the clock.
I've provided a link for what probably is the proper clock but without the full model number I can't say for sure:
http://www.appliancepartspros.com/frigidaire-clock-316207529-ap3764682.html
11helpful
2answers
Error f13 on my frigidaire oven how do i fix it
The "F13" error code means "Bad EEPROM identification/Checksum error".
If reseting the power did not help then according to Frigidaire suggested corrective action the electronic oven control (aka EOC) has to be replaced.
- The part number for the EOC is AP3874704
1helpful
Getting F13 err code when trying to bake or broil. Frigidare model PLES399EC
Hi william_j522,
the F13 error is related to the clock. this error can occur when the clock looses communication between the keypad or any of the sensor in the stove, including the heat probe. sometimes resetting the power will fix the problem.
try disconnecting power to the stove completely and flip the corresponding breaker on and off on the breaker box.
wait 30 seconds and than turn everything back on.
if the problem returns after power-up, replace the clock.
Regards
R.K.
1helpful
F13 flashes on my Frigidaire electric range
F-13
Control's internal memory may have
become corrupted.
1- Press Cancel key.
2- If fault returns disconnect power, wait 30 seconds and
reapply power.
3- If the problem persists upon power-up replace the display
board.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
WhenI try to bake or broil--get error msg. F13
Unplug the oven.
3helpful
Receiving Error F13
Turn the breaker to the stove off for one minute, reset time and everything should work just fine. It worked for me.
Ken
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
