Question about Hitachi 61SWX10B 61" Rear Projection Television
I have a Hitachi plasma TV model # (p50s601). When i had recieved the Tv I was aware that it was not in working condition so i brought it home and removed the backing to discover that quite a few wireing harnesses were diconnected. I pluged them back in and also pluged in the TV and the red light turns on at standby but when i hit the power button it turns on for about 2-3 seconds and shuts off then the blue ON light flashes 3 times. Can anyone help me out?
Posted by James Waterman on
Channels will not change with remote or at the TV controls
Have a close look at the owner manual or Google the model for one as many sets have a LOCKOUT that locks both the remote and front/side buttons on the set out.
Nov 04, 2012 | Hitachi Ultravision P50S601 50 in. Plasma...
My hitachi plasma tv model P50S601 only flashes a picture for a second before going black. Once it goes black, the blue power button flashes and can't be turn off by the remote or by manually pressing it...
These tv's are know for this. I have a topic about it telling you how to test and repair these at http://www.hometheatershack.com/forums/hitachi/38229-hitachi-p50h401-led-flashes-3-times.html
p50s601 and p50h401 are basicly the same tv but the p50h401 doesn't have the swival base.
these sets are known for two caps to go bad in the power supply and then most likely it fried out one or both of the driver boards. the driver boards can be repaired. a company that repairs them is listed in the topic. or you can buy new driver boards.
Apr 09, 2011 | Televison & Video
Instuction maual for hitachi plasma tv model no P50X01AU
These are the only manuals available. Maybe one of them will help.
  • Hitachi P60XR01U manual for Plasma TV
  • Hitachi P60XR01E manual for Plasma TV
  • Hitachi P60X901 manual for Plasma TV
  • Hitachi P55T551 manual for Plasma TV
  • Hitachi P55H4011 manual for Plasma TV
  • Hitachi P55H401 manual for Plasma TV
  • Hitachi P50XR01U manual for Plasma TV
  • Hitachi P50XR01E manual for Plasma TV
  • Hitachi P50X902 manual for Plasma TV
  • Hitachi P50X901 manual for Plasma TV
  • Hitachi P50V702 manual for Plasma TV
  • Hitachi P50V701 manual for Plasma TV
  • Hitachi P50TP01UA manual for Plasma TV
  • Hitachi P50TP01U manual for Plasma TV
  • Hitachi P50TP01EA manual for Plasma TV
  • Hitachi P50TP01E manual for Plasma TV
  • Hitachi P50T501A manual for Plasma TV
  • Hitachi P50T501 manual for Plasma TV
  • Hitachi P50T01UA manual for Plasma TV
  • Hitachi P50T01U manual for Plasma TV
  • Hitachi P50T01EA manual for Plasma TV
  • Hitachi P50T01E manual for Plasma TV
  • Hitachi P50S602 manual for Plasma TV
  • Hitachi P50S601 manual for Plasma TV
  • Hitachi P50H401A manual for Plasma TV
  • Hitachi P50H4011A manual for Plasma TV
  • Hitachi P50H4011 manual for Plasma TV
  • Hitachi P50H401 manual for Plasma TV
  • Hitachi P50A402 manual for Plasma TV
  • Hitachi P50A202 manual for Plasma TV
  • Hitachi P42TP01U manual for Plasma TV
  • Hitachi P42TP01E manual for Plasma TV
  • Hitachi P42T501A manual for Plasma TV
  • Hitachi P42T501 manual for Plasma TV
  • Hitachi P42T01UA manual for Plasma TV
  • Hitachi P42T01U manual for Plasma TV
  • Hitachi P42T01EA manual for Plasma TV
  • Hitachi P42T01E manual for Plasma TV
  • Hitachi P42H401A manual for Plasma TV
  • Hitachi P42H4011A manual for Plasma TV
  • Hitachi P42H4011 manual for Plasma TV
  • Hitachi P42H401 manual for Plasma TV
  • Hitachi P42H01U manual for Plasma TV
  • Hitachi P42H01E manual for Plasma TV
  • Hitachi P42A202 manual for Plasma TV
  • Hitachi P42A01 manual for Plasma TV
  • Hitachi CL42PD2100 manual for Plasma TV
  • Hitachi CL37PD2100 manual for Plasma TV
  • Hitachi CL32PD2100 manual for Plasma TV
  • Hitachi 70VX915 manual for Plasma TV
  • Jan 31, 2011 | Cell Phones
    Blue light blinks three times
    very common issue for these sets! p50h401 and p50s601 are almost the same.
    for more info on this set please check out http://www.hometheatershack.com/forums/hitachi/38229-hitachi-p50h401-led-flashes-3-times.html
    if will tell you how to trouble shoot this tv. these tv's are known for two caps in the power supply to go bad and they need replaced then you have to test the sdr buffer boards if they are bad you need replacement boards or you can send them off to be repaired.( Repairing the buffer boards is a lot less then replacing them ) the link for the repair guy is on the page. this guy also sells the repair on ebay but if you contact him directly i beleave the price is lower. just tell him you were send over by home theater shack.
    Sep 19, 2010 | Hitachi Ultravision P50S601 50 in. Plasma...
    Plugged the tv in, there is no power, the outlet is good
    If you can open your Plasma then open & checked Main Power cable is ok after that checked AC fuse inside your plasma if it defective replace and if again fails than replaced Power Board.
    Jan 23, 2010 | Hitachi Ultravision P50S601 50 in. Plasma...
    Cracked outside lens on 50" plasma
    If you want to try and disguise the crack, try some light clear parafin oil, mineral base, or clear silicone gel.apply small amount along the crack, then wipe off excess.
    Oct 03, 2009 | Televison & Video
    Hitachi Plasma P50S601 no picture sound OK
    probably needs new scan drive board along with upper and lower buffer boards. it wont be cheap and its best to have a tv shop do it.
    Aug 30, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
    Blue light blinking-
    I would say you are lucky to get a pretty fair price, sounds like a convergence problem- if the tv is a projection wide screen. worth the investment Julio [email protected]
    Jul 22, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
    Hitachi 61SWX10B 61" Rear Projection Television Logo
    Top Hitachi Televison & Video Experts
    matt martin
    matt martin
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
