Question about Lands Phones
Inter-Tel 8622 and 8662 phones won't power up once unplugged
We have about 50 Inter-Tel phones within the system. The problem we are starting to have is if the power goes out or we unplug to relocate a phone, some do not power back up and are essentially dead. Those who know the phones know that all the current and access comes through the data line. This is a random issue but is starting to become more frequent. The Mitel tech stated he was not familiar with the problem. That is was not widespread. Aside from thinking a capacitor might be getting a surge of some sort or after a certain amount of hours these phones just start to go, I'm at a loss. The phone system is just this month 5 years old. We should be able to get more out of these phones. I now have 2 boxes with 11 phones that are gone. In looking at the board I see no signs of broken connections or burns in the paths. Of course I want to get the phones fixed by a pro but also would like to know what we can possible do so this does not continue with working extensions. Thanks.
Posted by Dave Barrett on
  • Rob Pitts
    Rob Pitts Aug 31, 2016
    We have lost 10 phones, all either the 8662 or 8622. All of them after power outages!
Bruno Gervasi
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
We are having exactly the same problem. These phones are plugged into a Cisco POE switch which is plugged into a APC UPS, no way it can be a power surge problem, they are fully protected. We have had phones fail with a normal reboot of the switch. This is more wide spread then you may think. Our system provider tells me they have hundreds of these phones that have failed. It must be a simple fix on the phone since these same phones show up as refurbished. It would be nice to know what component needs replacing.
Posted on Jan 21, 2015
5 Related Answers
Anonymous
  • 13 Answers
SOURCE: I have an Axxess by
This is set up in the phone system programming as to what the mailbox is and the password. If you are not able to get in then you will need to call a technician.
Posted on Dec 08, 2008
paul proctor
  • 4102 Answers
SOURCE: Line in use
Hi this problem is more common than you think its caused by the power surge you get when the electric is turned back on you also get this problem due to lightning strike their is absolutely nothing you can do to repair the phone as their are no servicable parts and the chances of getting a new board for the base is going to be nigh on impossible
Posted on Feb 12, 2008
Anonymous
  • 201 Answers
SOURCE: Inter-tel Access
You definitely need to have a local phone installation company come in and help you with this. Axxess system setup and programming is extremely complicated for someone that has not worked with it and it requires specific software to make program changes. If you know the company that installed (or services) the system you should call them.
Posted on Nov 12, 2007
Anonymous
SOURCE: Inter-Tel Axxes phone outside calls don't go to voice mail
I had this same challenge with an InterTel 5000 system. Outside calls going right to the receptionist. My solution: You cannot fix this from a phone, you must open the DB Session Manager, move to Call Routing Tables (this is right above Voice Processor) and move all of your extensions above the "NO MATCH" and "EMPTY" lines on the bottom. Anything below those two lines will bypass the extension and go straight to the main attendant. At least in my configuration it does. See below...
bb752dc.jpg By just moving that last extension "5059" above the "NO MATCH" line, calls will now go to the extension from an outside caller. The trick is to hold your mouse on the pen icon and click several times to activate that line, then you can drag it to where you want. See below...
8e5e1dd.jpg Hope this helps someone?
vandata1
Posted on Mar 11, 2010
iandakin
iandakin
SOURCE: i have a vtech i5853 base and 4 other phones and
sell me your base, mine broke but my phones seem to work. 613 912 1422 ian
Posted on Nov 04, 2012
TG 9201 IS UNPLUGGED
Does this phone system have a central server? If so I would go check to see that it has power and came back up after the power outage. A lot of phone servers are on a battery backup and when the power goes out the software tells the server to shut down and then the UPS powers off.
1helpful
How do I change the display name on an Inter-Tel 8520 Axxess phone?
you have to login to the phone system and change it or if there is a phone with admin rights
When conferencing two outside parties, how can I (from the Inter-Tel Phone at the office) have myself removed permanently? When I drop off the line and leave the two people on, it rings me back to where I...
The Inter-Tel will not allow you to leave the conference without disconnecting the outside parties, this is the system design. The hold recall time could possibly be increased to reduce the aggravation.
Video Telconferencing drops at various times
If you changed providers I bet they forgot to provide disconnect signal on your lines.
This signal is sent to your system from the provider when a calling party hangs up and is transferred to VM.
A good tech with his phone should be able to see this while on monitor. You will need a system tech to verify this. Most likely it's the provider.
Typically between 450 and 900 ms. The higher the better.
Moving an existing inter-tel axxess system to new office
Move of a system requires cross connecting lines, stations, Voicemail, faxes.
If you are ok with doing this tasks then you could move it yourself. Power down. Disconnect current stuff. Move.
I suggest hiring proffesional though.
Cheers,
I have an Axxess by Inter-Tel phone system and I can not access the system administrator mail box # to get into the system.
Inter-tel 660.300 Intertel Premier 24 Button
Line could be dead from local provider (Verizon,etc.).Could be a bad port on the phone system. Maybe a bad connection into phone system. What Intertel system do you have?
Inter-tel Access
Inter-Tel AXXESS T-1 settings
Inter-Tel Axxess uses programming software specific to the version of software in the phone system. So, you need to know what software the system uses. If you do not already have the programming software... it's a huge hassle. The software is only available to Inter-Tel distributors.
Lands Phones Logo
Top Lands Phones Experts
Ekse
Oloyede Monsuru
Are you a Lands Phone Expert? Answer questions, earn points and help others
