I have tried using the download manager from Roadmate and no help. No matter what I do the unit always shows the same error message that the SD card has been removed. I am missing windows CE 5 and the specific 1412 firmware. I have even gone so far as to download windows CE 5 to the SD card thinking the unit would at least recognize the card and then do an update but no luck. I have also tried a new SD card, going through all the steps from above and still no help
SOURCE: I updated software on my
The software of the unit got wiped out when you formatted the roadmate. The reason your system gets hungup was because it is not able to carr the updates you downloaded on it. Therefore, the solution was for you to have reset the device.
Now what you will have to do is to get some help from magellan, because they are the only source you can get the operating system from. Try to contact them from their help desk of:
Monday through Friday, 6:00 a.m. to 5:00 p.m. PST/PDT Telephone: 800 707 9971
They would provide you with the operating system for your unit.
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
