Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
I have a 30 gallon Vanguard water heater 3WA79, i recently replaced the HWD Element due to the circuit breaker tripped. The element was broken causing the breaker to trip, now i connected back in plac
Is there a reset or how long do i need to wait for hot water
5 Related Answers
Anonymous
  • 79 Answers
SOURCE: no hot water.
Please get an expert in - this is either the breaker is faulty or you have an electric fault int he boiler. You can try and replace the breaker - but match the current rating. But this could be dangerous if you keep trying to reset.
Posted on Jan 25, 2009
Shadow1989
  • 408 Answers
SOURCE: Rheem Hot Water Cylider Thermostat keeps tripping
Sounds like you have a faulty thermostat.  This is the unit that detects the water temperature, and if it is not where it is set, will kick the switch to allow electricity to flow to the elements you replaced. The thermostats are relatively cheap and if you have the knowledge to change the elements, changing these thermostats should not be a problem.
Posted on Mar 07, 2009
SOURCE: after about an hour the breaker trips
I would say then the heating element has a resistive short to ground. The 1.98m Ohm reading is high, but not high enough -- should be infinite. I would say replace heating element... And, when you install new one, make sure there is no water leaking thru heating element cavity and ensure area around cavity is clean & "in order".
How old is water heater?
Charlie
Posted on Sep 29, 2009
Testimonial: "He was right on the mark, after removing the element it was apparent that it was bad, split down the middle of the element twords the middle section. "
Anonymous
SOURCE: Hello, I have a Rheem 81V52D 50 gal. residential
It's probably bad upper or lower thermostat.
BUT... new element could also be shorted.
OR ... original tank is rated 1500 watt elements look at label on side of tank.
I always replace both thermostats to save time.
Lower thermostat costs $10 at Lowes.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 17, 2011
barterjoe
Joseph Mueller
  • 346 Answers
SOURCE: My hot water heater tripped the circuit breaker on
Tough problem here. Most dual element heaters share one line. if this is the case and you have power on the top and none on the bottom I would check the connecting wires one to another. also check the settings of the thermostats. They may be adjusted all the way down. If the wires and connections are good I would recommend ohm testing the new elements. I have burned elements out by introducing cold water to very hot coils (forgetting to turn the water on after flipping the breaker)
Never forget that calcium buildup will short the element. If touching on the bottom you will burn it up.
If this does not help try borrowing hot water from neighbors ;)
Good luck
Joe
Posted on Feb 15, 2011
Testimonial: "top element = O ohms, burned out. Replaced top element, turned water on and waited for tank to fill this time "Prior" to plugging in. THANKS!! "
Electric went off the control panel is dark and no hot water
It sounds like you have electronic ignition for your burner and not a gas pilot. If it's an electric water heater than the problem is probably similar. There is a small transformer that interfaces with the knob that controls the water temperature. Sometimes they need a reset. Turn off the breaker , wait a few seconds, and than turn back on. If it's a gas pilot type it still has a transformer but the breaker trick may not be the solution...though it doesn't hurt to try. If this is the case you may need to relight the pilot. Follow the instructions located normally just above the water temperature control knob
Aug 22, 2014 | Rinnai Water Heaters
Rinnai RL94i - Produces hot water for 3 minutes, then stops
I just had this exact problem. It kept getting worse until we had no water. Our Rinnai tankless hot water heater started the same way though, with hot water for a few minutes and then would shut off with an error code 10. We just had to shut the hot water off and then back on, wait a minute or so and we had hot water back for a few minutes. Our unit would come on with a loud vibrating noise and remain until it shut off with an error code 10 (air flow fault). The solution was to remove the blower fan and blow out the squirrel cage. Ours had moths in it. We also vacuumed out the fan housing. Be careful to mark any wires you disconnect and take pictures before removal. Our unit is now almost silent when it comes on and supplies endless hot water.
Jun 10, 2014 | Rinnai RL94i Tankless Water Heater
Suburban Water Heater-Sw10de-10 Gal Gas/Elec W/Direct Spark - 5063A
Manual Yes 12 volts may help. I can't see anything about your switch from this manual
Dec 02, 2013 | SUBURBAN MANUFACTURING C Suburban Water...
Model 71-52DB 50 gal. water heater stopped heating
Press the reset button located on upper thermostat
Following link has troubleshoot for electric water heater
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 13, 2012 | Rheem Water Heaters
No hot water
test the thermostat and the heating elements --also there are resets that can pop push and make sure they have reset
May 17, 2017 | Water Heaters
I have no hot water in my home i can not locate the reset button
The reset button is located on the top thermostat, on the heater you will see a acess panel with screws in it to remove the thermostat and element is behind this panel. Once removed the top thermostat should have a red button to press to reset heater.
If it resets then wait for a little time for hot water. If this doesn't work then it could be the elements are in need of changing.
Apr 09, 2011 | General Electric GE SmartWater Household...
Reset button for tankless water heater
you need to unplug the unit, wait for 30 seconds reset the temp to the lowest temp, then try it, if this does not work it might have done something to the circuit board, are you on a gfi out let it needs to be there is water and ele, and should be on the gfi with a reset on it,,
Jun 01, 2009 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
I painted the floor & my hot water heater (Reehm
The water heater is locked out. The following process should reset it.
1. Reapply power to the water heater and wait for 3 seconds for the system self-diagnostic check.
2. Within the first 30 seconds, the temperature dial must be rotated back and forth crossing the 120
degree mark at least six (6) times. This will reset the control and display a normal flash code
(slow blinking).
Mar 22, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water heats for about 3 seconds and goes cold
Take the cover off and look for reset that has trip.If you can't find no reset turn the power off and wait for five minutes,turn on and turn water on also to see if you get hot water.
Mar 14, 2009 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
185 people viewed this question
Top Rheem Water Heaters Experts
Bill Johnson
john h
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
