It is not auto start and you turn knob hissing sound would come out and then you light it with a flame it has butane in it won't light i thought maybe needs cleaned or get replacement nozzle
SOURCE: all of a sudden my
it can actually be your starter. many times a bad starter just wont turn at all. it can be that, a short, or the only other thing i can think of would be a blown starter fuse. you can check your fuse box in the engine compartment, it should be like a 50 to 80 amp fuse thats in a little clear box in the fuse section of your fuse compartment. hope this helps. and if fuse is good, you can try poking the starter with a stick and try to start. if it does something after poking it, then its the starter
SOURCE: Car wouldn't start. Thought
did they run a test on the alternator!! at battery when off should be at least 12.6 volts, less than 12 volts battery is bad. when running at battery voltage should be at least 14.1 to 14.7, thats if alternator is ok. if less than above replace alternator. if alt. is ok, could be a bad battery.
SOURCE: 1994 camry won't start after cleaning under
Sounds like wet or moist spark plug wires. If this also occurs during early morning high dew point humid air, then you may have spark plug wires shorting out.
Replace wires.
SOURCE: My car was running, then
You need to have the cam angle and crankshaft position sensors checked. These are 2 parts which enable the ignition system to fire. If these are ok then check that the rotor in the distributor is turning when you crank the engine.
If it is not turning then you have a cambelt/chain or gear problem which you will need to repair before it will start again.
Hope this helped.
Thanks
Jason
SOURCE: vw polo abs light won't
Well, first of all, did you fix the problem that caused the fuse to blow? Have you scanned you Antilock Brake System (ABS) module for fault codes? Since the computer is the one responsible for turning the light on, wouldn't you think that the computer would be the one to ask WHY it has turned the light on?
Please also review the following articles:
Where's The Fuse?
What Else Could Be Wrong?
