How to remove freezer back panel to acess cooling fan
SOURCE: Freezer / Refrigerator not cooling
When the fans are running the compressor should also be running. If the compressor is hot but not running you have a compressor problem. If the compressor is running check for frost on back wall of the freezer compartment which would indicate a defrost system problem. At five years old have you cleaned the condenser where the heat is transferred to the outside air in the room?
SOURCE: Whirlpool refrigerator
iam refrgeration mech have one now doing same thing put piercing valve on found that cop tube is blocked have found other refrigeraton units using 134a gas blocking cap tube systema
SOURCE: ice accumilation next to fan in freezer compartment
u have a defrost problem need to replace heater and tstat
SOURCE: whirlpool freezer not freezing
The fan speed can be deceptive. That is why this problem is so hard to diagnose, when the fan starts to wear out the motor spins but not with enough force to circulate air thru the freezer and rrefrigerator. If you have the ability to swap out the fan motor then it should only cost you the price of the motor and components. Approx. $125.00 if you have the make and model you can go to appliancefactoryparts.com or appliancefactorypro.com to obtain motor and components, But if you have to get serviceman to replace fan it will cost you an hours labor also.
SOURCE: whirlpool fbb36af20/2 fridge freezer frame of
Hot frame is mullion heaters. Keeps moisture from forming on door and causing rust. Sounds like the connector is defective, remove connectors and wire direct. If fan won't run then you need to call a qualified service tech.
Testimonial: "wired direct as sugested running ok thanks ian"
