SOURCE: I have the SC272TB Double
The issue with those Thermador wall oven and freestanding range doors ( especially on the freestanding "professional" line ) is the weight of the door is so great, the hinge will actually move slightly over time, other times the entire hinge will need to be replaced.
Recommendation: Adjust the door box hinge per instructions below. 1. Pull the oven away from the wall about 12". 2. Remove the hinge box cover plates. 3. Remove the vertical side trim piece. It covers one of the screws that must be loosened. 4. Loosen the 4 screws that secure the hinge box. 5. Place a rolled up dishtowel at the bottom of the door and close the door and apply light pressure to the door while re-tightening the four screws. See fig below 6. Re-install the hinge box covers & side trims. 7. Re-install and secure the oven. That should do it, ( or as stated, improve the situation ) if the hinges are too far gone they will need to be replaced unfortunately. Let me know if you require further assistance or if indeed this solved your problem. Macmarkus :)
Welcome to FixYa.
Yes this has been a fairly common issue with the Thermador wall ovens as well as their freestanding ranges.
Typically the remedy will be replacing the hinges, but there is a "fix" you can attempt in the interim. At least in hope of keeping the oven light from being on all the time, hence damaging the control board which houses the oven lights transformer.
This is what I'd recommend ( also official Thermador remedy, rest assured as I am a authorized factory trained Thermador service provider ) before pronouncing the hinges need replacing though.
**This does require a somewhat involved repair, so if you don't feel completely comfortable or have any reservation to trying this, please call in an local authorized Thermador ( B/S/H/ ) service provider.**
Thank you for choosing FixYa today and good luck going forward.
Regards,
Hi The issue is with the door latch-switch assembly that is bad
and should be replaced. Hope this helps...please post back for further
assistance. Daniel
Hi
The door
lock assembly is bad and should be replaced, you can try to move it but that
won't help and will have to be replaced to solve this issue. Hope this
helps...please post back for further assistance.
Daniel
