Question about Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN All-In-One InkJet Printer
Cannon mx860 fails to print in black ink. loaded new cartridge, still doesn't print in black. will print in color..
Posted by lew12010 on
Mike Smith
    Scholar:
    New Friend:
  • 65 Answers
With the Canon MX860 you can removed the print head assembly quite easily and clean it with water. I have posted a youtube video for your reference.
Posted on Jun 03, 2015
Chris Hingee
  • Canon Master
  • 32,281 Answers
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Posted on Mar 06, 2013
5 Related Answers
Anonymous
  • 103 Answers
SOURCE: cannon ink jet quit printing black
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel. # Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right). # Continue doing this until it looks clean. # Then dab the cartridge on the towel to make sure the ink is flowing. # Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier. 2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Aug 21, 2009
Anonymous
  • 48 Answers
SOURCE: black ink out--can I print in color instead
first go to the control panel,second click on printers and hardware,third click on printers and faxes.fourth highlight your printer,right click on it.fifth,go to properties,and then click quality.you should be able to change it from there.good luck,hope i helped
Posted on May 01, 2009
Anonymous
SOURCE: Cannon Pixma 160 - How do I reset the ink level indicator
crapt the driver
Posted on Oct 21, 2008
Anonymous
SOURCE: cannon MP210 printer
I tried this and it worked (thanks to a suggestion from someone else but can't find his name right now) --
I found a slender piece of cardboard, the front off one of my 1-subject notebooks. I cut the jagged edges off, made sure there wasn't any debris or loose crumbs of paper. Put about 20 sheets of paper into the printer and put this cardboard as the first sheet. Pressed the copy button. When it started to attempt to feed, I forced it through.
What did it find?? A moth had flown into the printer at some time, gotten smushed, smashed and stuck -- and was preventing the paper from feeding through! OMG, I almost tossed this Canon MP210 in the garbarge.
So thanks to you guys with ideas about cardboard and a little muscle. I ran another piece through just to clean out all the stickiness (and the remnants of the moth's body). Works fine now.
webstuff
Posted on Mar 12, 2009
don_farr
Don Farrell
  • 1018 Answers
SOURCE: Why two black ink cartridges?
The larger of the two cartridges is used for text only. The smaller is used for color printing. Its purpose is to eliminate the need for a "Processed" black (black being mader by the color inks).\
Don
Posted on May 30, 2009
Override empty ink tank on Canon PIXMA MX860
The title of this topic is for the MX860. It has no "RESUME" button, so the advice submitted by cene765 does not work. But there is a solution.
The MX860 has two black ink cartridges--one small (like the colored ones) and one large. So, you will run out of colored ink way before you run out of black. I found that by selecting the "Gray scale" printing option, I could still print with color cartridges being very low. Even when the printer told me that the color cartridges were empty, I could still print by clicking the "OK" button. However, this does not last. Eventually, the printer will flag the color cartridges with an alarm. When that happens, the printer stops working, freezing at the alarm until you replace the cartridge.
However, you can still print. What you need to do is press and hold the STOP button for a few moments. The alarm will be released and then you let go of the button. Printing can resume. This happened to me where the alarm was triggered by the cyan cartridge, before I could even try to print. When I used the STOP button bypass, printing started but was then flagged by the magenta cartridge. I thought for sure that pressing STOP while in the middle of starting the print cycle would abort it, but thankfully it did not--the alarm was cleared and printing resumed.
May 24, 2012 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Can i send a fax without ink?
my fax machine is a Canon mx860. it would not let me do ANYTHING without a black ink cartridge, even tho all the color cartridges were full (black can be made without a black ink cartridge, it just waste your color ink a lot.)
Since it was an emergency i scanned the document to fax from my desktop as a .jpg file, sent it to my laptop containing a modem, and faxed it from my laptop with windows 7's "fax and scan wizard". I know its not a fix, but its an emergency work around.
May 23, 2012 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Why is my black ink not printing
Hi Colleen,
Try this > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences' or 'Properties'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc... , there click 'Ink cartridge settings'.
- A small windows opens, there select black only. See the image
- try printing, if it fails to print, just return the cartridge to the shop and get a genuine branded one. (dont forget to change the 'ink cartridge settings to normal to 'both black and color')
Hope this help, if you are not able to fix it still, then better come to chat here , thanks! 10_22_2011_5_46_32_am.jpg
Oct 22, 2011 | HP Photosmart C6380 All-In-One InkJet...
I ran out of both black and color ink. I replaced the black ink b/c I do not print in color. But I cannot complete the alignment steps without the color ink.
Lexmark printers usually require both cartridges to have ink left in them to continue printing. But try to press the Cancel button for the Alignment process (this is not recommended). Then try to print a document again to verify that you are able to continue printing without an empty color ink.
If that doesn't help, I would suggest you replace your color cartridge with a new genuine Lexmark cartridge.
Sep 12, 2011 | Lexmark X2690 All-In-One InkJet Printer
My printer will no longer print in black s520
if it is a new black ink cartridge and the printer still wont print black start by:
A: Simply making sure the settings are ok. To do this, go to file>print. When the printer box shows up. click properties.
From there, you will be able to see color settings. (ex. black, grayscale, full color.) Try switching to black or "use black cartridge only.
B. If "a" does not work for you, the print head which hold the ink cartridge is clogged or no longer working. Through the cannon window on the printer, try running a print head cleaning or any maintenance program.
If there's still no black, the print head has seen better days and needs replacing. Most of the time it is more effective to get a new printer.
May 22, 2011 | Canon Office Equipment & Supplies
My mx860 is printing fine for every ink cartridge except the big black one. it hardly prints the black ink at all - sometimes i just get a black page. this is recent - after a month of not using it. i...
Hold a piece of tissue under the ink jets and see if the tissue draws ink out of the cartridge. If not the cartridge is blocked or empty. If ink does come out there may be a faulty contact on the cartridge or printer. Try swap out the cartridge with a known working one and see if that works.
Jan 26, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I replaced a new cartridge to my printer and now is not printing. Before I tried to refill the cartridge and it did not work, it was leaking black ink. Now with the new cartridge it does not work either....
Canon PIXMA MX860. Turn it off. Open it and check if the black ink leaked inside most especially on the cartridge panel. Clean there using surgical spirit or petrol using a cloth.
Fit the cartridges in their actual point (Black and Color). Connect its power and USB cables and then switch on. This should work for you.
Jun 15, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
My black ink will not print. Do I have to have
The larger of the two black cartridges is used for text only printing.
The saller cartridge is used for black in graphic images or pictures.
This saves you color ink . It allows you to put the black ink on the image without making the color inks blend the black ink.
Don
Jan 31, 2010 | Canon PIXMA MP780 All-In-One InkJet...
What is the cartridge number of HP 4335 all in One Printer
the part number is hp 21 black injet print cartridge part# c9351aa, hp 22 tri-color inkjet print cartridge part# c9352aa cartridge for everyday printing and the high volume printing cartridges hp 27 black inkjet print cartridge part# c8727aahp 22xl tri color inkjet printer cartridge part# c9352ca; these cartridges is for hp officejet 4355 all-in-one inkjet printer
Nov 21, 2009 | HP Officejet 4355 All-In-One InkJet...
I have a cannon MP160 printer. Color ink button is flashing. The color ink cartridge is empty. I replaced the black ink cartridge and want to print in blank ink only. However, I can't get the color light...
try to go into the software for the printer and find a rest ink cartridge button. This will make it think it has a new one which wil let you print in black by selecting black print only
Jan 08, 2009 | Office Equipment & Supplies
Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN  All-In-One InkJet Printer Logo
704 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
