Televison & Video Logo
What is the weight of the television?
Serial # 750322154 Chassis # CTC187AJ
How to check service tag on supermicro servers
AFAIK Supermicro is not using Service tags like Dell or Lenovo. Instead they go by serial numbers. The location of the serial number depends on the type of the server:
Blade serial number (SBI... or SBA...) is located on the side
Blade Enclosure serial number (SBE...) is located on the rear side
CMM (chassis management module) serial number (SBM...) is located next to the latch
Rack-mountable chassis serial number is located on side of chassis by the sliding rail
4U Tower Chassis serial number sticker is located on the bottom side
Rack-mountable Systems' Serial Number is located at the rear side by I/O panel
Embedded Systems' Serial Number is located on the I/O panel
Check this website for more:
http://www.supermicro.com/support/SNGuide.cfm?sn=ss
I need the serial number for an RCA 22" tv with DVD model number LED22B45RQD
Its serial number should be with its back cover; either on a sticker or hard printed. If not, can get this information by its chassis inside.
Electro help
I lost my remote for my Zenith Tv Chassis No. CN-00IC serial no. 951-13430147
Just buy one Zenith universal remote control. It can be setup with this TV
1helpful
What are the dimensions of the bebecar m city?
The details are as follows ;-
1. Chassis folded size - 36.6 in X 20.5 in X 8.7 in
(93cm X52cm X 22cm)
2. Chassis weight - 25 lbs (11.4 Kg)
3. Carrycot weight - 15 lbs (7 Kg)
4. Seat weight - 13 lbs (6 Kg)
5. Seat width - 13.4 in (34 cm)
6. Handle height - 37-42.9 in
7. Wheels - Swivel
8. TSC - Yes
Good Luck!!
Thanks!!
3helpful
Wd 62725 timer light keeps blinking
The Chassis Assembly needs to be sent to Mitsubishi for refurbishing. Call 1800-332-2119 and the Customer Service Department will help you contact a local service facility to you remove the Chassis and reinstall it when completed. They most likely also will help with the cost of the repair. When you call them , have the model # and Serial # . This repair would normally cost about 850.00. If they help with the cost, you would probly look at around 350.00.
I hope this helps,
Skyassoc
14helpful
How do I know if it is L6 or L3 chassis
you need to look on the right side of the set (facing the front of the set) for a small label that says
model code...
serial number..
version..
if the version number is blank or PW01 you have the
L3 chassis.
if it says PU02 then you have the L620 chassis
also the L3 chassis has the ballast on a slight angle and the L620 has the ballast straight.
2answers
1helpful
Rca projection tv serv#p56938yx mod#p56938 serial#c135c50tx chassis#ptk195s16p cant id
Here are some numbers to call for Flyback Replacement
Electronica 1-800-772-5578
Asti 1-800-221-1828
you will need RCA chassis# PTK195s16p - flyback number1541938b.
ThankYou for using FixYa. Have a Nice Day.
RCA P52920BL
i'd like to help.that model# looks familiar.but that chassis num you gave looks more like a serial num all my rca prints go buy chassis # is there anothe num like ctc197 exet or ptk19 doc
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
