Trying to install after market radio and need the color codes on the harnes to figure out speakers & 12v output
SOURCE: wiring harness for 2004 dodge
2004 Dodge Ram 2500 Truck Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
SOURCE: 97 dakota installed radio harness have power no sound
If you still haven't fixed this, look at your wiring harness. The blue wire that comes off your factory harness is the external amp in the Infinity stereo. I found this out when I hooked my Pioneer head unit up. Coming off the aftermarket stereo should be a blue wire that says remote. Hook those up and you should be good to go.
SOURCE: i need the color codes 4 a 1998 dodge ram 1500 radio wiring
I am not sure for which wires set you are looking for.
You can go to www.autozone.com then go to repair info, and you can find your free online repair manual.
This is my main source for automible repair info
SOURCE: WIRING CHANGE FOR 2002 DODGE CARAVAN
Your best bet on that one is to go to a place that sells car audio systems or even some autoparts retailers have them,and get the proper adapter harness already made up. A few more dollars but, a whole lot less headaches.
