Question about Dell Latitude D600 Notebook
Dell D620 laptop screen won't come on after disconnect from docking station
Dell D620 laptop is hooked to docking station with monitor and works fine. Disconnect from the docking station and open laptop and the screen will no come on. However, laptop indicates that it has completed a full boot. How do I get the laptop screen to come on?
Posted by John Merlin on
ernesto cuadra
    Top Expert:
  • Dell Master
  • 12,223 Answers
Please use the following small secret. Disconnect the power adapter from the laptop.
2) Dissasembly the batteries from the laptop.
3) press the power button in ON with the adapter+battery disconnected from the computer. and maintain press the power button by EXACTLY 60 seconds.This liberate the ESD.
4) Try again.
God bless you
Posted on Mar 05, 2013
5 Related Answers
Anonymous
  • 21 Answers
SOURCE: Dell Latitude d620 display problem
Sounds like your computer has just bit the dust, do your self a favor and purchase a new one. This time buy an XP, it might be a little bit more, but you get what you pay for.
  `Nbryson
Posted on May 31, 2009
Anonymous
  • 4 Answers
SOURCE: inspiron 600m,"no input signal check video cable"?
Do you have an external monitor for use when the laptop is on the docking station? If so, does your laptops screen come on when it's not docked?
If you're using an external monitor while the laptop is docked, make sure that the screen selection is for external monitors, by pressing/hold the FN key and then press the F8 key to cycle through the choices between LCD, Monitor/LCD or Monitor only.
Posted on Mar 11, 2009
Anonymous
  • 253 Answers
SOURCE: Monitor not working on Dell Inspiron laptop. Inspiron 1501 laptop
just follow the given link ur problem will bw solved
http://www.experts-exchange.com/Hardware/Q_21896519.html
Posted on Jun 25, 2009
SOURCE: Dell latitude d810 laptop won't full boot on just battery power a
Connect the AC Adaptor to the Computer and turn it ON. Then, open the Run dialog box and type "msconfig" to open Microsoft System Configuration window. On the System Configuration window, click on the Startup tab then check if the checkbox beside the "LoadPowerProfile" program is marked. If yes, then shutdown the Computer. Then, remove the Battery pack and clean the Battery compartment and the metal contacts using a pencil eraser. Furthermore, you may try resetting the BIOS to its default values after reinserting the Battery.
Restart the Computer and keep on pressing the F2 key until the "Entering Setup" text appears on the screen. Then, press the "Alt+F" key to restore the BIOS to the default configuration. Then, press ESC and Enter to Exit and save the changes.
Posted on Sep 04, 2009
Anonymous
  • 3940 Answers
SOURCE: dell latitude 830 completely black
You have a motherboard failure. Replacement motherboards can be found on EBay. When I looked, prices ran for $170 and up
Posted on Sep 14, 2009
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Dell E6520 does not activate docking station LCDs
Sounds like the docking station needs to be cleaned.
WHen I hook my laptop to my external HP 22" monitor, using my HP docking station, it recognized the monitor but the externalk monitor stays dark. Every so often it will flicker and then give the...
no laptop stated ok W7 OS, nice to know.
hopeless?
nor external model screen stated
try a different external screen
any shop can fix it, ask them
no need to ship anything
get it checked out by a technician
we can test all 3 parts and tell you whats worn i minutes.
i can not understand your post
try to be more clear
does local LT screen work ok
does using a known directly connected screen (VGA)
on the LT you must turn on external screen using the fn hot key
the the external works,. do so, now
if both internal and external fail the LT is bad, guess, bad GPU chip
if only external fails, try a known working external screen
if that works your external is bad.
the docking is last, and if only it fails, then ITS BAD.
2answers
My dell 620 battery will not charge with the power supply, yet it charges in the docking station. The laptop will run fine with the power supply except that the battery will not charge till I place the...
sounds like the situation is with the AC adapter detection. try to restore your BIOS defaults and update BIOS if applicable. Test another AC adapter. If that fails, most likely, this is with the motherboard. You may either get a new board, or just continue to charge it using the docking station.
When disconnected from docking station touchpad
there are fixes on dell support site for this, goto dell support and enter your mdoel number for laptop and search for its drivers solotiions, also do same for docking station. http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=dhs&cs=19
1helpful
Hook up dell laptop to docking station: I have a dell lap top inspiron 1721 and a dell model # PRO1X docking station, I would like to hook it up in my home office. I have never done this before and just...
this is easier than you think my friend, firstly put the dock on your desk, plug in power lead, network cable and monitor cable, place laptop on dock (making sure it clicks into place) turn on dock and monitor and your up and running
My dell monitor flashes on and off when I put dell laptop on dell base station. Eventually it settles after the flashing becomes less and less. I have put dell laptop on another identical setup, base...
There is something wrong on your DOCKING STATION ( as what you mean the "base station". Hope I'm right with the things you mention. Docking station not working okay though. Try to call DELL technical support for some solutions for this issue. If it can be resolve over the phone then fine but if not then they either replace the docking station or have it repaired. Thank you.
Close to the same issue, Latitude D520 freezes at random
Have you checked the system events? I suggest you check the device manager too, is there any device working unusual? Feel free to visit digitalsupporttech for getting help.
Inspiron 600m,"no input signal check video cable"?
Dell Latitude D600 Notebook Logo
Ekse
Mandeep  Singh
Mandeep Singh
Michael Thomas
Michael Thomas
