The belt is broken
SOURCE: REPLACE BELT ON AMANA WASHER
REMOVE THE FOUR BOLTS HOLDING ON THE MOTOR MOUNT TO THE MILK STOOL. DISCONNECT THE DRAIN HOSES, UNPLUG THE WIRING HARNESS AND THEN ROLL THE BELT OFF THE MAIN PULLEY OF THE TRANSMISSION. FLIP MOTOR OVER AND REMOVE THE DRAIN PUMP, NOTING HOW THE BELT WAS THREADED THROUGH THE PUMP MOUNTS.
SOURCE: AMANA WASHER WON'T SPIN. HOW DO I REPLACE THE BELT?
is this a whirlpool built amana? if so, its most likely a direct drive model, and when it doesn`t spin its likely a coupling between the gearcase and motor assembly...youtube has videos on how its replaced, which isn`t too complicated to do...good luck
SOURCE: Replace Broken Belt
Here is the link that will explain how to do it:
http://www.applianceaid.com/amana-wash.html#belt
check this link u ll get if u dint really sorry for in convinience
SOURCE: Need diagram showing Amana ALW880QAW belt replacement.
This doesn't explain how but it may help anyway. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ALW880QAW&productCategoryId=0153200&brandId=1268&modelName=AMANA-LAUNDRY&diagramPageId=00005&componentDescription=MOTOR,%20PUMP,%20BELT%20&%20IDLER&documentId=M0512380&backToLink=Return%20to%20Sub%20Components%20list
