Question about Epson Stylus CX5400 All-In-One InkJet Printer
Printing card stock on Epson Stylus NX420 - Epson Stylus CX5400 All-In-One InkJet Printer
5 Related Answers
Anonymous
SOURCE: Epson Stylus C86 won't print
The ssc program doesn't work if your ink light is solid red.
Posted on May 01, 2008
Anonymous
  • 33 Answers
SOURCE: epson stylus pro 4800 print head problem
Are you getting a nozzle check at least?
Posted on May 14, 2008
Anonymous
  • 163 Answers
SOURCE: epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Posted on Apr 03, 2009
aicaxz
Anjazmoro Wicaksono
  • 511 Answers
SOURCE: Printer won't accept Card Stock
Nothing to adjust feed mechanics. If it's temporaly print, you must feeed paper 1 by 1, and when printer grab paper, push paper by hand. If it's routine print, you can adjust the pick up rubber at paper feedr mechanic. Add double tape ( 1 mm, soft) below top rubber. I have done it, and printer can grab/feed paper up to 350 grams.
Posted on Jun 30, 2009
Grant Meier
  • 352 Answers
SOURCE: i cant print on white
Try placing some standard paper behind the vellum paper, it might assist in holding correctly while printing.
Being so thin the paper I would guess is folding up under the print head? if so look through all the printer properties, under the maintenance section there may be a "set Plattern Gap" (set to wide) or "Thick Paper Setting"
Selecting these raises the print head up to allow for thicker paper to pass through, but can also help thinner paper from folding up under the heads.
I hope one of these works for you.
Regards GM
Posted on Apr 12, 2011
Magenta is not printing
Cartridge is not workin corretly. Return it from where you bought it
Oct 05, 2014 | Epson Stylus Nx420 All-in-one Inkjet...
HOW I CAN PRINT WIRELESS
Printer needs to be on the wireless network, then setup the PC with printer wizard using the IP to identify the printer. You may even try entering it in the Run / Search for auto setup by Windows. Both have to be on same network.
Nov 26, 2012 | Epson Stylus Nx420 Color Ink Jet...
How do u check ink levels on the Epson NX420
Go to a webpage file in the top left hand screen, once there click page preview then hit print once in the print preview and finally hit the properties button to see the ink levels.
Nov 16, 2012 | Epson Stylus Nx420 All-in-one Inkjet...
Epson stylus nx420 will not feed paper
If this is an older printer, the pickup "fingers" get worn and need to be replaced
Oct 11, 2012 | Epson Stylus Nx420 All-in-one Color Inkjet...
How to change Ink Cartridge on Epson NX420
you have to pull out scanner unit upward. you can see all four cartridges. now you can change cartridges.
Jan 17, 2012 | Epson Office Equipment & Supplies
I cant print on white vellum paper on my epson stylus nx420 i need to print some invitations and it is just folding my paper
Regards GM
Apr 12, 2011 | Epson Stylus NX400 InkJet Printer
My epson sx600fw prints ,after that it then comes up with paper jam any one know how to sort the fault
Go To Below official Epson Printer Page For Your problem, Epson Stylus NX420 All in One Printer
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
Nov 28, 2010 | Epson Office Equipment & Supplies
Epson Stylus cx5 series
Is media transparent? Epson paper sensor think that no paper. Put white stiker at top left and right of media (about 1 cm height and 2 cm width). It's for tricky sensor.
Jun 28, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
1,219 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
