Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Installed a mitsubishi 62530 lamp and the orange light is still on
Posted by Christina Lashley on
Robert Smith
    Champion:
  • 213 Answers
DO YOU HEAR THE BALLEST POWER UP AT ALL IT MAYBE BAD OR DI YOU PUT THE DOOR BACK ON THE LAMP ?
Posted on Nov 25, 2013
4 Related Answers
Anonymous
  • 111 Answers
SOURCE: I have a mitsubishi wd-62530 that I have just put
dm module has bad caps on it
Posted on Feb 03, 2010
Anonymous
SOURCE: WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Posted on Jul 14, 2010
phatcav
  • 126 Answers
SOURCE: mitsubishi 50 inch .lamp needed to replace lamp
Was the lamp replaced? Have you gone in to the service menu to reset the lamp hours? Also what model is the tv -
thanks,
micheal
Posted on Feb 25, 2011
SD Tech
SD Tech
  • 14553 Answers
SOURCE: mitsubishi wd-60735 replaced lamp. tv still wont come on. orange flashing light
This set should have a self check:
Posted on Dec 07, 2012
Just put a new lamp in my 92in Mitsubishi tv and know a orange light was blinking what is that
You may have solved it by now, but the lamp access door needs to be installed or the orange light will flash.
May 06, 2015 | Mitsubishi Televison & Video
I replaced a mitsubishi tv 62530 lamp. When I turn the tv on now the picture does not come on and then the tv turns off. What can I do?
Hello, it sounds like the lamp has gone bad. Unplug the tv and check the lamp and see if it's broken inside. here's a link on how to do that.... www.youtube.com/watch?v=90dfZGQoY8Q
Jan 03, 2015 | Mitsubishi Televison & Video
I replaced the lamp on 62530 worked fine for a few days, now the picture won't come on and the lamp light does come on.
unplug the unit wait 30-60 seconds & plug back in. Try unplugging your source at TV input & then plug it back in
Jan 03, 2015 | Mitsubishi Cooling Fan Set for WD-62530
My 62 inch mitsubishi projection tv comes for about a minute then goes out with the lamp light on what is the problem
I would suspect if when it comes on it is a bit dark it may be the lamp itself---when was last time set was serviced or lamp replaced---by service I mean these sets need to be cleaned out inside from dust or dirt building up in the air channels---this will also shut the set down.
Lamp failure is much more common than the ballast.
Nov 05, 2012 | Mitsubishi 935D8840 Interface Board for...
I have a mitsubishi wd 62530 08' model had blue showing through left side of tv working towords the middle, screen looks greenish yellow what is the problem
This is a known issue with these sets.
They use an OPTICAL LIGHT ENGINE which the lamp shines directly into: the blue section (it has blue,red and green sections with lens and baffles) is the first to get hit by the light and its heat.
Commonly it burns that area (blue) first.
This is permanent damage and either the display chip has to be replaced (over 200 part and not a do it yourself replacement) or the entire engine has to be replaced.
Sony and similar brands have the same problem--Sony is fixing a lot of them even if out of warranty for free (class action lawsuit!).
This is a 98% certainty in your case.
You may want to contact Mitsubishi to see what if anything they will do.
You might not get a straight answer from them so GOOGLE the model number and research this on the internet-------
Apr 01, 2012 | Televison & Video
II HAVE A 65" MITSUBISHI TV MODLE WD-62530 JUST
move all other electronics away from the screen mine did it too
Nov 17, 2010 | Mitsubishi WD62527 62 in. LCD HDTV
My wd-62530 model tv lihgt lamp comes on.the bulb is new.one day old
According to page 81 of your owners manual you are to contact Mitsubishi in the event the red light is on. Here is the paragraph from the booklet.
Service is required. Contact your dealer or a Mitsubishi Authorized
Service Center to arrange for a service evaluation. Listings
of Mitsubishi Authorized Service locations can be obtained from
our web site, www.mitsubishi-tv.com or by calling 1-800-332-2119.
Nov 25, 2009 | Mitsubishi WD62527 62 in. LCD HDTV
I have a Mitsubishi Tv wd 62530 and the lamp light is read Tv will not work
YOU NEED TO REPLACE THE LAMP THE OWNERS MANUAL GIVES YOU DIRECTIONS ON HOW TO DO THIS.
Sep 14, 2009 | Televison & Video
Can you please explain how to install the lamp light for my Mitsubishi WD-62530 TV?
http://www.youtube.com/results?search_type=&search_query=915P043010&aq=f
Hope this helps like it helped me.
Dec 31, 2008 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
96 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
