Question about Kingston DataTraveler 310 DT310/256GB Flash Drive - 256 GB
How do i format the kingston datatraveler 310 256 gb to ntfs file system
So that the drive will accept 4gb + files
Posted by joe houk on
Hans Pedersen
  • 3,606 Answers
Hello insert the drive in the usb port.
When you see the drive in the control panel, right click on it and choose format.
Select NTFS in the selection box, and mark quick format and click start.
This could take a while.
You just have to save ALL the previous saved files, before you format, because the files will be lost, when the the drive is formatet.
Good luck
Posted on Mar 16, 2013
5 Related Answers
Benimur
Louie Role
  • 6966 Answers
SOURCE: FLASH MEMORY (PEN DRIVE)
I would venture that your pen drive has a problem with its File Allocation Table. Being a 256 leads me to think that it has been in service for quite some time. Perhaps a full format is necessary. May I recommend that you use HP Drive Key Boot Utility available here. Of course formatting would erase all and everything inside the pen drive.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 25, 2008
theobituary
  • 6 Answers
SOURCE: Kingston Flash Memory not working
could be a bad card or the card reader/writer does not support that high of a capacity memory card.
Posted on Feb 11, 2009
Anonymous
SOURCE: Increase the Memory capacity
jUST CONTACT ME AT [email protected]
i will tell u how to compress ur files and put files of 2gb in 1gb penndrive without any kind of loss of files as u say
Posted on Aug 13, 2009
vickyakon11
vicky rajput
  • 68 Answers
SOURCE: kingston
sir if you are using adaptor of memory card for connect it with pc then i think this error occurs so use card reader and then insert the memory card in it..........the right click on the removal disk and click format when you click on format then click quick format then o.k if this error occurs again then scan the device or go to device manager and then check whether the property of usb is enable or disable if error still continue then mail me at [email protected] i will help you again take care
Posted on Mar 26, 2010
nathan
  • 634 Answers
SOURCE: When i copy any data to my 32 Gb Kingston pen drive whether any audio or video file or any software, the data get corrupted
Try formatting the drive, right click select format, and you can also try system tools and scan drive for errors. possibly defective.
Posted on Jun 09, 2012
I bought a Kingston Datatraveler 32 GB but when copying files of 5 GB or more I got a Message that the file destination on the datatraveler is too small
You might need a bigger drive ?
In the Microsoft Windows operating system, you can copy and paste 5 GB files as long as you have enough disk drive space. The disk drive to which you're pasting the file must be formatted using the New Technology File System (NTFS), which supports the copying and pasting of very large files.
Purchase a large capacity USB external hard disk drive from a reputable vendor. Make sure that the hard disk drive is at least 100 GB. Connect the external hard disk drive to a spare USB port in your computer. Wait for the Windows operating system to recognize the hard disk drive. Double-click on the "Computer" icon on the Windows Desktop, after which a window will appear listing all of your disk drives. Establish the letter of the new hard disk drive you have just installed. For the purpose of this article, the drive letter is assumed to be "E." Right-click on drive "E," click on "Format," change the file system to "NTFS," then click on the "Start" button. Wait for the process to complete. Click on the 5 GB+ file to select it, then press "Ctrl" + "C" on your keyboard to copy the file to the Windows Clipboard. Click on the "Computer" icon on the Windows Desktop, then double-click on the "E" drive. This will open the root folder of the hard disk drive in the same window. Press "Ctrl" + "V" on your keyboard to paste the 5 GB+ file from the Windows Clipboard to the new hard disk drive. Wait for the process to complete, which will take several minutes.
File transfer software http://www.filebuzz.com/findsoftware/High_Speed_File_Transfer/1.html http://download.cnet.com/Fast-File-Saw-Joiner/3000-2248_4-10388628.html When e-mailing or archiving huge files, it sometimes helps to cut them into smaller pieces. Fast File Saw & Joiner does exactly that, and puts the pieces back together, too.
Mar 02, 2013 | Kingston DTIG3/32GB 32GB DataTraveler G3...
Window was unable to format my 32 gb kingstone pendrive
To solve the problem use HP USB DISK STORAGE FORMAT TOOL V2.1.8. You can find it at http://files.extremeoverclocking.com/file.php?f=197. Do not format your 32GB Kingston PenDrive with NTFS file system since it does not function. Use FAT32 instead.
Jan 04, 2013 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Why can't my Toshiba ext hdd accept files more than 4GB? those files are .mkv formats. thanks!
The Toshiba is formatted with the 'FAT32' file-system, which is limited to 4GB per file.
Your 'C:' disk-drive is formatted with the 'NTFS' file-system, which has a much-larger limit.
So, use the 'DISKPART' command-line utility to "convert" the Toshiba from FAT32 to NTFS.
DISKPART is easy to use, but be careful to use it correctly.
Apr 23, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
Kingston Data Traveler 2.0 64 GB USB - file system corrupted - need to work on windows XP- Upon formatting the pen drive It shows that it has become a raw drive - wat is the file format for the USB to work...
Theoretically, you can't format a more than 32 GB drive with FAT/FAT32 file system. In your case you have to choose the NTFS file system to format your 64 GB USB flash drive. However, if you really need to format it with FAT32, you got to use the command line or a third party tool. Hope this is going to help you.
Apr 06, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I can't format my 2gb kingston data traveler 2ntfs and it stores only less than 28 mb. i can only use this data traveler on my microsoft office word and excel files but about my audio files, all could be...
I have kingston datatraveler 200 (64gb) and I backum 4gb`s on that usb, but when I want to opet that, its corrupted, damaged and now I cant even format my usb.. help
Dec 18, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My datatraveler 64gb dont formating in my
datatraveler dti.4gb ""the disk in drive E is not formatted" how to solve my problem
Dec 17, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
KINGSTON removable disk error
Find and check real free space go to my computer and right click your driver letter and click properties it will show what is real ammount of disk. For one 4GB file it must not be problem but for meny little file can take more space besider their sum of capacity is 4GB. At format check correct ammount of data "capacity" is 8GB (7.9) also file system for NTFS or FAT32. FAT cant bear 8GB.
Aug 04, 2009 | Computers & Internet
Kingston Datatraveler 2GB Failure
Try formatting the drive. Should be a problem with the file system.
Jul 26, 2009 | Kingston Technologies 512MB DataTraveler I...
Cannot copy 4.53 GB mpeg file to 8GB pendrive
http://www.kingston.com/support/USBFlashDrives/faq/pcdt_30.asp
Jul 09, 2008 | Electronics - Others
Kingston DataTraveler 310 DT310/256GB Flash Drive - 256 GB Logo
561 people viewed this question
Top Kingston Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Mike
Harish  Ramaiah
Harish Ramaiah
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
