Step 1:
Click start Control Panel. Select "User Accounts and Family Safety," then "User Accounts." Click "Turn User Account Control on or off." Remove the check mark next to "Use User Account Control (UAC) to help protect your computer." Click "OK." Set All Accounts to Administrator Still in the UAC section of Control Panel, select "Manage another account," and click on a user account. Click on "Change the account type." When working with multiple accounts, some changes can only be made if you and the account holder are both logged in with "Administrator" accounts so you need to change all user accounts to "Administrator." When you are done making changes, you can change them back to "Standard," but always leave at least one "Administrator" account. Select the "Administrator" radio button. Click "Change Account Type" at the bottom right. Repeat this procedure to change each user account to "Administrator." When all user accounts have been changed, close the Control Panel. Create a Full Administrator Account Click "Start" (the Windows Vista icon in the lower left of your screen). In the Search box, type "cmd". Right-click on "cmd," and select "Run as Administrator." An elevated command prompt window will appear. At the command prompt, type "net user administrator /active:yes", and press "Enter." Choose a password and assign it to the "Administrator" account, by typing "net user administrator 'password'", where 'password' is your selected password. For instance, if your password is "abc," type "net user administrator abc". Press "Enter." Type "exit" and press "Enter." Log off. When you log back into your "Administrator" account, you will have full rights.
SOURCE: HP Pavilion s3020n memory upgrade
They are usually in a plastic caady which has a latch on it find the latch and release the caddy hope this helps
SOURCE: HP Pavilion slimline s3320 hard drive replacement instructions
Hello, the service manual can be found here.
And if you could give this solution a fixya rating, I'd greatly appreciate it. Thanks! :c)
SOURCE: My Hp Slimline won't recognize my new Simple Tech Mini-Drive
I`m David ncc student , question is about the characteristics of various network computers (NCs) currently on market? please help me
SOURCE: need to format the hard drive for HP Pavilion
If you own the computer and it is still in warrenty then i would call up HP and explain the situation and have them send you a recovery disk, if it is not in warrenty they may still do it but if it doesnt work your other option is to purchase one or to Pirate one which wouldnt be illegal if you used the product key that came with your computer.
SOURCE: HP Pavilion Slimline s3122x powers up fan runs
Hi Im Rain.
I may have bad news for you. Its a very bad sign when your keyboard and monitor are not working at the same time. Sounds like the technician was right.
I also think its your motherboard. If you really just like the computer you can invest in another motherboard.
Testimonial: "Thanks so much. I appreciate your help. A new motherboard will probably cost more than a new pc. Thnaks for such a fast response."
