Cars & Trucks Logo
Jack Betts Posted on Mar 04, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why won't my driver's door open from the inside on my 2007 Ford Fusion?
I have to pull both the inside door handle and the lock below the handle simultaneously to open the driver's door from inside. How do I diagnose and fix problem?
Drew Orosz
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 18, 2014
Drew Orosz
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
23263
Points
The plastic lock and door latch handle are probably breaking. Common problem. A new handle combo from Ford is not very expensive and will only take an hour or two for a DIY novice to R&R.
Swiggs
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 34 Answers
  • Posted on Mar 04, 2013
 Swiggs
Expert
Level 2:
New Friend:
Greenhorn:
Answers
34
Questions
Helped
6561
Points
198
Pull on the outside handle up once, then reach inside through the open window and unlock the door, try this and it may correct it self
5 Related Answers
Anonymous
  • Posted on Apr 10, 2009
SOURCE: 2006 Ford Fusion inside door handle stopped working
The plastic door handle is broken.
You will need to get a replacement door handle.
Go to http://www.flickr.com/photos/gtppilot/sets...57607539089979/
This should help. It is a set of photographs and instructions to do the job of replacing the handle.
Good luck.
Rgrdrake
Mechanic65
Timmy L Costa
  • 142 Answers
  • Posted on Oct 07, 2009
SOURCE: Passenger sliding door doesn´t unlock (Power
Sound like you have a dammaged door latch assembly. It is a pain but you have to take the insid door trim panal off to see what you are doing and make sure the latch assy is un locking. Dis connect power door lock motor linkage to make sure motot is not jaming the lock in the lock possition.
Testimonial: "Thank you gives me at least an idea what I´m looking for. Now I can go see and ask in some shops"
myearwood0
  • 93 Answers
  • Posted on Dec 30, 2009
SOURCE: Rear door will not open on my 2007 Ford Fusion.
use the fob and keep clicking unlock/lock button see if everything is moving.then try banging outside of the door about 6 inches from door handle while pressing unlock.has worked on some other cars like vw audi and vauxhall
john h
  • 29494 Answers
  • Posted on Mar 13, 2010
SOURCE: 2007 chevy tahoe driver side door handle will not open door
the linkage behind the handle either the retaining clip broke or popped off need to remove the door panel to check and fix
Testimonial: "Thanks I thought it might be a cable or linkage. Much thanks"
kevingsuzuki
  • 752 Answers
  • Posted on Mar 14, 2010
SOURCE: inside door handle stopped working
the inside door hanger came off you need to remove inside door panel a couple of screws and need to pop off panel to replace hanger
tip
Door handle repair for Ford fusion
The door handle will not allow unlocking from the inside. This is a common problem with the Ford Fusion 2007 to 2012 and other cars. A cheap piece of plastic breaks that connects the lock lever with the door handle. You can roll down the window and unlock from the outside or hold both levers together and pull open from the inside. This is a very simple repair. Go to any of many web sites for auto parts and buy a replacement. I bought a Dorman 81702 Ford/Lincoln/Mercury Interior Front Driver Side Replacement Door Handle. I popped off the lid that covers a hidden screw inside the recess of the door handle. You have to use a torque bit to unscrew the screw. I then unscrewed the torque screw holding the upper part of the door panel that is opposite the door hinge. The upper part of the door panel can be be carefully pulled away with moderate pressure allowing access to the door handle mechanism. One more bolt holds the door handle part in place. Pull out the broken door handle part, remove the locking cable and put in the new part. Reverse the process to finish up. The whole process took about 10 minutes.
How much would it cost to get front driver door fixed that won't open on inside on 2009 Ford Fusion
need to take panel off and check the little plastic clip that hold the rod in place probably broke or fell off
2008 ford fusion driver side door will not open from the inside
You will need to remove the door handle, but you may have to pull the door trim plate first. Pull the handle assembly outward and inspect it to make sure the inner door connector rods are attached. These are held in place with plastic pieces, and plastic parts on the door handle. Replace the handle if the rod loop is broken. Replace the door rod ends with new hardware. This can all be done in your driveway, and requires very little mechanical knowledge or skills.
3helpful
The inside door handle won't open door from inside outside door works fine it's on drivers side 2006 ford fusion selv6
It sounds like the connecting rod popped out of its plastic connector. Pull the door panel off and check both ends of the rod. It must be unhooked at one end or the other.
2helpful
2answers
2006 Ford Fusion. Left front door inside handle
This link is from the handle to the latch. The door panel has to be removed in order for this problem to be fixed. The linkage is inside the door panel, it is a small diamater metal rod called a link. If you do the job yourself be careful not to break the door panel. In a shop, the labor is 1 hour for the job & if any, parts will be a seperate charge.
Rear door will not open on my 2007 Ford Fusion. It won't open from the inside or the outside. I removed the interior door panel and can look inside the door. I can see the mechanism for the outside door...
17helpful
5answers
Good luck.
Rgrdrake
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
