We did only one cycle, and it couldn't drain, so I would be surprised if it's a clogged drain problem. Another thing, the right support in the front isn't keeping his correct height, so the dishwasher doesn't stay at level. When we put it at level, we hear a sound, but it doesn't drain nevertheless. Finally, the dishwasher is stuck on his cycle because it won't drain.
SOURCE: need bosch dishwasher manual
Try putting in your model number here to get access to documentation....
http://portal.bsh-partner.com/portal%28bD1lbiZjPTA2MA==%29/PORTALFRAME.HTM
SOURCE: Dishwasher wont finish cycle
I have experienced this problem before and it turned out to be the main control board in the console. Not a cheap fix, either. The control boards are not serviceable, and can run over $100. Sorry, I hope I was of some help.
SOURCE: Bosch SHU430UC/06
ok first of all there is a drain pump and wash motor pump. which one is running?Then tell me what kind of buttons u have.Are the touch buttons or plastic buttons that move
SOURCE: Drain was clogged and the dishwasher overflowed.
Probably the aquastop (if you have one). We have a similar problem after our owerflow. The dishwasher is starting and running through the programs but no water is coming.
SOURCE: Dishwasher will not finish the cycle. Display will
Hello, welcome to Fixya. I know this post is a few days old, but in the event you haven't found a solution yet I'll throw my 2 cents into it. I suspect the "1" is actually an error code and not coincidentally the reason it doesn't dry. Here`s the most likely reason why it has detected the error... Even if your home water supply appears hot, it's not hot enough and must be heated by the dishwasher to insure a proper clean and dry, hence most if not all manufacturer`s do this. When it comes to your Bosch dishwasher the problem likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s and display`s the error "1" telling you it can`t heat the water. ( I can send you documentation directly from B/S/H/ confirming and explaining this if you'd like to post your email address ). **Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on their behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)** **Please disconnect the power before attempting any service to the dishwasher** Installing a new control will certainly remedy the problem as well. But when it is priced at about $170.00 I am more likely to offer someone an alternative to buying new, hence my first reaction to mention this repair tidbit. The control is available at most brick & mortar appliance parts stores or on-line at vendors such as "repairclinic.com", "apwagner.com", "searspartsdirect.com" etc. part number is based on your specific model number so you`ll need to provide that. Hope this answer`s your question's, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied. Good luck. macmarkus :)
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
