Question about Nikon D3000 Digital Camera
I dropped my Nikon D3000 and cannot get camera to recognized that the lens is attached
I tried attaching another Nikon lens and the lens not attached error remained
Posted by lynette on
Art Scott
    Novelist:
  • Nikon Expert
  • 357 Answers
If you remove the back cover, there is a flexible circuit on the bottom left that attaches to the rear circuit board. Check to make sure that there are not cuts in the lands caused by impact pressing the flex into the back board components. This is a common problem with this model.
Note: replacing this calls for removal of the mirror box. Nikon stopped selling parts on July 13, 2012. You may be able to find it on Ebay.
Posted on Mar 08, 2013
5 Related Answers
patmartini
  • 6 Answers
SOURCE: "Lens not attached" warning when lens is in fact attached.
Hello. Check the area around the lens mount carefully - specifically the contacts. Make sure all are clean and protruding the same. If one is lower than the rest, try 'flicking' it with a fingernail (lightly) to see if it will pop up to the height of the others. It may have dirt or a particle of dust lodged. If this doesn't help, get the lens to Nikon for a check-up.
Posted on Jun 06, 2008
Ty Price
  • 11967 Answers
SOURCE: My computer doesn't recognize that my nikon
Try re-booting your computer. If that doesn't work, why not try a separate card reader instead of your camera?...works every time.
Posted on Dec 26, 2009
Ty Price
  • 11967 Answers
SOURCE: CAMERA SAYS LENS ERROR, HASNT BEEN DROPPED/ HIT,
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jun 07, 2010
Ty Price
  • 11967 Answers
SOURCE: I have the Nikon D3000
Clean the contacts on the camera body and the lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Posted on Oct 25, 2010
akangpepen
Steven Pepen
  • 133 Answers
SOURCE: Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
Posted on Jan 03, 2011
Nikon d3000 has 'lense not attached error'
What lens do you have attached? If it's an older lens with the electronics, the camera will not be able to communicate with it and thus report lens not attached. You can switch to manual mode and still use the lens, but you'll have to set the exposure without any assistance from the camera's light meter.
It it is a more modern lens with the electronics, try cleaning the contacts on the back of the lens and in the mount on the body.
Oct 28, 2013 | Cameras
Dropped my d3000 camera and now when i turn it on info screen says lens is not attached, changed lens but still get the same message
Uh oh...you are going to need to service it....there is a sensor that prob got broke/disconnected when dropped. It will need to be professionally serviced. Sorry for the bad news!
Feb 16, 2013 | Nikon D3000 Digital Camera
Promaster lense fits nikon D3000 but camera says lens not attached
Promaster makes many different lenses. Some of their older lenses do not have the electronics to communicate with newer digital cameras, and you have to shoot in Manual mode. Could you tell us which lens you're asking about?
Nov 30, 2012 | Cameras
I recently obtained a used Quantaray for Nikon 500mm f8 f/8 Mirror lens. I have a Nikon d3000 and I am not sure how to attach it to my camera.
For Nikon AF and manual focus SLRs. The compatible T Mount System makes it possible to use most any single lens reflex camera in combination with various front camera attachments such as telescopes, mirror lenses and slide duplicators. The T Mount is a metal connector that screws onto the compatible front attachment and allows this combination to be coupled to the SLR camera lens mount.
Nov 30, 2011 | Quantaray 500mm/1000mm Preset Telephoto...
Tried fitting manual tamron lens with adaptall2 convertor to my d3000 but i get a lens not attached message.can this be overridden?
Yes. Since the lens does not have the electronics necessary for focusing and metering, you just have to do everything manually. Set the camera's mode dial to M for manual. You can then set the aperture and shutter speed.
Nov 04, 2011 | Nikon D3000 Digital Camera
My nikon d3000 lens is saying it isn't attached when it is, i've tried cleaning it, taking it off and everything and nothing has worked. what do i do?
If you can go to a camera store or any store that sells this model, and has a display model out, you can try putting another (same) lens on your camera. If the problem still occurs, we know the issue is with the camera body sensors.
If it shows as connected with the new lens, we know that you will need to have the lens serviced or replaced.
Once you find out, repost your problem with more details, or consult with your local camera shop.
You can also call Nikon Tech Support at:
Nikon Technical Support
8AM - 2AM (Eastern)
7 days a week
1-800-Nikon-US
1-800-645-6687
May 06, 2011 | Nikon D3000 Digital Camera
Is the Wide angle converter (Nikon Wc-E68) compatible with the D3000?
No. The converter is intended for certain point&shoot cameras. It is designed to fit in front of the much smaller lenses. The D3000 has interchangeable lenses, so you can simply remove whatever lens you have on it and attach a wide-angle lens.
Feb 14, 2011 | Nikon WC-E68 0.70x Lens Converter
I have the Nikon D3000 and it is telling LENS NOT ATTACHED when the lens is attached.. what do i do? is there a way to fix it..?
Oct 25, 2010 | Nikon D3000 Digital Camera
I keep trying to attach the lens and it keeps saying "lens not attached" on the screen. What should I do?
1.the lens is not suitable for newer Nikon DSLR, e.g AI-Nikkor or PC
2.try to clean the mount part at the camera and at the lens with clean-dry cloth
3.probably there`s some malfuntions inside the camera, please refer to your Nikon retailer
May 20, 2010 | Nikon D3000 Digital Camera
Nikon D3000 Digital Camera Logo
443 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nikon Camera Expert? Answer questions, earn points and help others
