Question about Toshiba Satellite P105-S6084 Notebook
Where is the location of the CMOS Battery on a Toshiba Satellite P105-S6084
Location of the CMOS Battery on a Toshiba Satellite P105-S6084
Posted by tomsr1 on
joecoolvette
  • Toshiba Master
  • 5,660 Answers
5 Related Answers
Anonymous
SOURCE: Trying to locate the cmos battery for Toshiba Satellite L25-S121 laptop?
On the Toshiba Satellite L25 S1217 Laptop, the battery is indeed to the left of the wifi card. I was having a problem with a bios password and had spent a considerable amount of time looking. However Instead of taking the whole laptop apart, I removed the wireless card and used a precision flathead to maneuver the connector out of it's socket. after a few seconds I booted the laptop, with the battery still disconnected , and no password prompt! using the same screw driver, I was able to get the connector back into it's socket, and put the wireless card back in. it runs fine now. the trick is to only pull the connector out only enough so that it's not making the connection, if you pull it too far you will have a tougher time guiding it back into the socket. I hope this helps a lot of people with the same problem.
Posted on Apr 30, 2009
BJ HALL
  • 13 Answers
SOURCE: want to replace cmos battery in Toshiba Satellite A10
On Toshiba laptops you hit the ESC key as soon as you turn it on & then you
are given the option to hit the F1 key to enter bios.
As to the cmos battery, they couldn't have hidden it better if it was the Queen's diamond!
It is near the bottom of the laptop on the right side, almost directly beneath the pause/break key.
Problem is, you have to disassemble the entire laptop to get at it!
Disassembly instructions for the Satellite A10 are here
http://www.irisvista.com/tech/laptops/ToshibaA15/SatelliteA15_laptop_disassembly_1.htm
Best of luck
Barb
Posted on Mar 03, 2009
Anonymous
  • 674 Answers
SOURCE: BATTERY CMOS LOCATION TOSHIBA SATELITTE L300
battery cmos location in toshiba l300 insid the motherboad in leaft side near in hdd but you should open all the reset it if necessary/
Posted on Jun 26, 2009
Anonymous
  • 58 Answers
SOURCE: Toshiba Satellite A100 755 battery CMOS
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
50
Posted on Jul 26, 2009
Anonymous
  • 120 Answers
SOURCE: How do I replace the CMOS battery on a Toshiba
http://www.tomshardware.com/forum/247842-30-replace-cmos-battery-toshiba-satellite
Posted on Oct 15, 2009
I shut down the laptop at once and i turned it on immediately.so only power light is on and the computer is not working.only black screen is seen.
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
Jul 11, 2011 | Toshiba Satellite P105-S6084 Notebook
There is a transparent column on my toshiba p105-s6084 screen. is there an easy fix? Or, do i have to buy another screen?
If the problem is also on an external display then maybe Windows Side Bar is loaded with no gadgets.
Otherwise a replacement screen is the answer.
See ebay for prices and availability.
Dec 13, 2010 | Toshiba Satellite P105-S6084 Notebook
Does the toshiba satellite p105 s6084 support ACHI
Yeah it does support ACHI but you have configure it.
Please let me know if you have any further questions or concerns.
Thanks.
May 01, 2010 | Toshiba Satellite® P105-S6084 PC Notebook
Has power, but will not post up or go thru boot
Hello my friend,if you sure that is having power and is not motherboard or CPU error then you should try resetting your bios settings or check if the bios battery is dead.You should take it to a repair shop to take a look or tell me if you want to try to change the cmos battery but remember that the warranty will be void and you may harm your computer.
Feb 06, 2010 | Toshiba Satellite P105-S6084 Notebook
NO power
Check the battery of your notebook pc .
when you charging it then try to turn it on if it starts and shuts down when you remove charging them there must be problem of the battery,then you have to change your battery from Toshiba service center.
Oct 23, 2009 | Toshiba Satellite P105-S6084 Notebook
When I play DVDs in my toshiba p105-s6084, it skips in sound and sounds all sketchy. It plays cds ok. what is wrong?
Sounds like you need to update the DVD Decoder, A very good decoder is Nvidia, roxio and Power DVD are ok. Hope this was helpful Good Luck =)
Jun 05, 2009 | Toshiba Satellite P105-S6084 Notebook
I have a Toshiba Satellite P105-S6084 My daughter turned it on. Windows started to load and then everything went blank and the computer refused to be turned on again. No sign of power
Take battery out of the back of laptop, put back in. if that doesnt help:
1.) remove battery from back of latptop
2.) remove cmos battery should be accessable through one of the panels on bottom of latop.
Are you getting any beep codes?
Jan 20, 2009 | Toshiba Satellite P105-S6084 Notebook
P105-S6084 Does not turn on at all.
i think you're right!you have to replace a new one honestly
Dec 31, 2008 | Toshiba Satellite P105-S6084 Notebook
Toshiba Satellite P105-S6084 Notebook Logo
2,200 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
