Question about Dell PowerEdge T300 Server
Server Randomly Reboots
My Dell T300 (w/ Windows 2008 Server) is acting very weird, every couple days or every other day, the server all of the sudden reboots. This server normally during POST the fans speed up really high for few seconds and slow down to normal speed, but whenever the server has a sudden reboot, it stay stuck at the fan high speed for couple minutes with nothing on the screen, then it proceed to POST and everything goes back to normal, but last weekend the server got stuck on high speed fan for 2 days, nothing on the screen, had to pull the plug, and plug it again to work. I have looked into windows log and has absolutely no information why it's rebooting, only thing it says, the server had an unexpected shutdown, that's all. I ran all the hardware diagnostic tools provided on Dell server CD and everything passed with no problem. What could it be the problem??? Power supply maybe??? Thank you.
Posted by Daniel Matos on
Jax Planet
  • 923 Answers
First, go to Dell's website and update all the firmware and install the latest version of Dell Server Administrator. DSA has logs information not logged by Windows. Next, take it outside and blast the fans with compressed air, make sure all components and cables are properly seated in their slots/sockets, turn it on with the cover off and make sure all the fans are spinning. Many servers will increase the fan speed if they detect the cover is off so this is another possible cause to the problem.
Finally, Dell servers have lifetime support, this number should work: (800) 945-3355
BTW: A temporary workaround might be to use a network controlled outlet that you can remotely turn off and on. Your UPS might be able to turn outlets on and off or you could get a stand alone network controlled outlet. Some can actually ping the device and turn power off and on again if it stops replying to pings. (E.g. IP Power EV-9255 IP http://www.newegg.com/Product/Product.aspx?Item=9SIA1470N64280)
Posted on Mar 06, 2013
2 Related Answers
Anonymous
  • 12 Answers
SOURCE: I have Dell PowerEdge T300
You will need the drivers for them i had a similar problem
insted of reinstalling windows i got a very old taty keyboard and mose from a windows 95 pc
and used them till i got and installed the drivers for them.
Posted on Dec 27, 2010
maaaartin
  • 561 Answers
SOURCE: Dell PowerEdge 1500SC that started to reboot itself randomly but now switches off within a minute of startup
assume power supply is failing or overheating, suggest replace power supply for new one or one with higher power rating to cope with power demand.
I hope this was useful.
Posted on Oct 20, 2012
Testimonial: "Thank you for your help. I bought a new power supply and it all seesm fine now."
How can i istall windows server 2000 on Dell Poweredge T300
Windows 2000 is not supported on this machine. The closest you could get is using a hypervisor XenServer or VMWare ESXi and then installing Windows 2000 on a virtual machine.
Jan 26, 2015 | Dell PowerEdge T300 Server
Error code 2900-0325
Use GOOGLE and SEARCH for:
First Search for:
Dell PowerEdge T300 Server list of Error codes
(12,600 hits)
then search for:
Dell PowerEdge T300 Server Error code "2900-0325"
(You will find 40 'hits')
Anthony
Sep 14, 2013 | Dell PowerEdge T300 Server
Error message on server says to call support.
Disassemble Components an Clean the System with Air blower,
& Assemble Components Check it
Aug 26, 2012 | Dell PowerEdge T300 Server
I have a dell power edge t300 server. i need to install windows 2003 server. i dont have dell cd for windows 2003 server. while installing the hard disks (scsi) are not detected and setup aborts. how can...
If your Dell server cam with the Windows Server 2003 software, you should be able to order a replacement cd. Go to http://www.dell.com/support If the software was not packaged with the server, you will have to buy it at http://www.microsoft.com/sales
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Jun 23, 2011 | Dell PowerEdge T300 Server
Cannot install windows 2008 server r2
the server wont work with server 2008 due to bad sata drivers.
Feb 17, 2011 | HP Compaq ProLiant ML110 G4 Server
I have Dell PowerEdge T300 server, running Windows 2003 SP2 after I finished the installation and every thing was ok, and the server reboot many times , the keyboard and mouse stopped working and I can't...
Dec 26, 2010 | Dell PowerEdge T300 Server
Nic teaming on poweredge t300
NIC teaming is useless unless you have a switch that support teaming.
However, Dell servers have free lifetime phone support ((800) 945-3355).
They should be able to help.
Jul 26, 2010 | Dell PowerEdge T300 Server
Dell PowerEdge 2300 - Monitor, keyboard and mouse will not respond
It sounds like the power supply is failing.
Failing power supplies will sometimes deliver just enough power to make the fans spin but not enough for the motherboard and drives to start.
I hope this helps.
May 28, 2009 | Dell PowerEdge 2300 Server
Dell says I could not load WinXP Pro on Dell T300. Why not?
You won't encounter any problems, but you may need a usb to ethernet adapter to get on the internet to get drivers. Also, many places no longer sell non-OEM copies of windows XP, and, will Dell sell a computer with no OS?
Mar 18, 2009 | Dell PRO/1000 PT Quad Port Server Adapter...
Monitor and keyboard will not respond
It only happens with your keyboard and mouse? or does it include your monitor too? if it does include you monitor then it is the video card. It is built in to your system and is causing the problem. I got the same issue before. My mouse doesn't work, keyboard won't respond, monitor is blank. I know its the video card. It is not typical for a server to respond that way but you need to replace the system or replace the video card...
Dec 10, 2008 | Dell PowerEdge 2300 Server
Dell PowerEdge T300 Server   Logo
334 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
