Question about U-Line CO2075F-B Echelon Refrigerator Ice Maker Combination
Samsung SRS757DW freezer is freezing up
Freezer is freezing at back wall of unit and freezes around the icemaker container and ice exit. Could this be the fan has packed it in or what?
5 Related Answers
Rich Wright
  • 286 Answers
SOURCE: icemaker fills with water..the ice freezes but does not dump.
I dont believe its too much water. You may have a problem with the heater not coming on. If your icemaker advances then the termostat is calling for it. The ejector blade would bounce from the 1 oclock to the 2 oclock position until the heater warms the mold enough to allow the ejector blade to push the ice out. If the heater is out I would replace the complete icemaker
Posted on Jun 28, 2009
Neciforo Llanto
  • 942 Answers
SOURCE: ice maker shooting water along wall of freezer
Hi...
You need to check this
Regards
PCmania
Posted on Jul 08, 2009
Anonymous
SOURCE: my icemaker will run water
I did not ever speak with a person. Got disconnected.
Posted on Sep 15, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: my u-line icemaker will freeze long enough to
Remove the bottom panel and clean the finned coils .
Posted on Jul 03, 2010
daniel matthews
  • 157 Answers
SOURCE: undercounter icemaker is cold but
The water solenoid valve controls flow to icemaker you can put 120 volt to it and see if it opens .If it is good then its not getting power when icemaker calls for fill
Posted on Jun 22, 2011
Fridge leaking water and noisy fan in freezer
I'm going to guess this refrigerator has an icemaker in the freezer. The water leak may be from the ice maker filling process. If that is correct, the water sometimes gets behind the freezer back wall and re-freezes around or near the fan blades causing the noise. Just a guess with out a brand name and model number.
May 01, 2015 | Refrigerators
Several times now my freezer & refrig. stopped working. Ice buildup on back of freezer wall. Especially if there is content in it. The icemaker I think was spilling water down the back (missing the...
Sounds like one or more of you defrost coils behind the back wall have gone bad...
You have to purchase the correct coil set for that model, remove the back wall, replace them and put the back cover back in place after emptying the entire contents of the freezer...
Most non HVAC people would prefer a repairman to do it.
Mar 09, 2014 | Kenmore Top Freezer Refrigerator
Ice block
There is some cooling in the freezer which is allowing the temp to raise above freezing for a brief period. Check gaskets and or the temp setting. Is ice cream hard or soft. Ice cream freezes at around 15-18 degrees. My guess is that the door gasket is allowing air inside the box.
Feb 03, 2013 | Samsung RF265AA Bottom Freezer French Door...
Icemaker freezes up and deposits ice at the bottom of the compartment. My icemaker seems to freeze up and stop producing ice while dumping the water to the bottom of the freezer compartment where is...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze and can't go where it's supposed to. You can take the water line off the valve and watch to see if it drips.
Nov 05, 2009 | Samsung RS2630SH Side by Side Refrigerator
No ice
Pour about 1/2 cup of water into icemaker . If it freezes and dumps , the water valve is bad ( where the wall water line connects to the fridge ) . If it freezes and does not dump and the ice stays in the icemaker , replace the icemaker . Also check the fill tube ( the tube going from the freezer wall to the icemaker itself ) to see if it has frozen closed . If it has , the water valve is not closing completely , and letting a drop thru and freezing in the tube . Also an indication of a bad water valve .
Aug 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Ice Maker won't work
If your trying to save a service call you have your work cut out for you. The ice maker is a unit that sits by itself attached to the wall or part of the freezer wall.
There are many reasons why you do not get ice and I will list them.
1- Temp of freezer got too cold and has frozen the pipe that feeds the water to fill the icemaker.
check to see if the icemaker has any ice in the area that fills and makes the cubes.
If the pipe is clogged, very gently put a small tipped screw driver in the fill hose that sites over the ice making row in the ice maker. Be careful you do not push your screwdriver out the back of the refer.
Check to see the freezer temp is not too cold and is freezing that pipe. 0-3 degrees F is good.
2.- check to make sure your water feeding the fridge is on. There is an on off valve to allow the water to feed the icemaker when it needs to fill. This could be bad. there are reset proceedures for the fridge, but unplugging the entire frige for 1 minute and plugging it back in you can listen for the the valve to come on and see if it fills the ice maker resevoir.
3. If it fills and freezes the ice resevoir, then the sensor in the ice tray does not sense the frozen ice and will not cycle and kick cubes. At this point, unless you are super tech, you will need to replace the entire icemaker unit.
Hope this helps.
Mar 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Feb 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Icemaker is not freezing ice, freezer not freezing food,
The ice maker won't work if the freezer is warmer than 17 degrees so that's not an issue till you get the freezer cold again. I would guess that your unit is stuck in the defrost cycle. This could be the defrost timer failing. See if you can find the defrost timer in your unit and advance it by hand if possible. http://www.partselect.com/PartSearchResults.aspx?modelnum=jcd2295hes&mfgmodelnum=&fkmfgid=1&hint=defrost
Dec 01, 2006 | Jenn-Air JCD2295HES Side by Side...
Refrigerators Logo
49 people viewed this question
Top U-Line Refrigerators Experts
Marvin
Marvin
Kardoc
Dale Copeland
Dale Copeland
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
