I cannot obtain any of my saved PDF files. I am receiving a message that my Nitro has stopped working.
Still getting the issues with nitro program or with your computer give us a call (877-330-0887) Kindle Technical Support Registration 877 690 9305
SOURCE: Adobe Acrobat 6.0
Normally if you click on help at top of menu, then detect and repair normally sorts it out
SOURCE: It is not possible to obtain device's certificate. e250
WMP11 is not without its glitches but if you want a good sync without many problems use WMP10 it has many more capabilities and upgrades than the 11 considering its relatively new i also have the Sansa e250 surprinsingly enough it holds 4 gigs not 2
SOURCE: Canon imageRUNNER 8500 scanner to PDF files
With acrobat full version and network scangear, or you can buy the option "send kit" .
SOURCE: Cannont scan to PDF or RTF with HP PSC 2410 All-In-One InkJet
You have a problem with your scanner software or your operating system.Try connecting you scanner to another computer, install the software, and try scanning.
SOURCE: I have the Printmaster Platinum Version17 , I cannot save to pdf files?
1. In Tools/Options/General Options, check the box beside "Optimal Printing Resolution".
2. Go to File/Printer Setup/Printer Setup.
3. Under "Name" select Broderbund PDF Converter v2.10d
4. Next, go to File/Professional Printing.
5. Select "Save As PDF".
6. At the next screen, type the name of the PDF file you want to save in "Project Name".
7. Under "PDF Resolution", select 600 dpi.
8. Click on "Save As". In the next window, browse to the folder in which you want to save the file (for example: My Documents).
9. Click on the "Save" button.
10. PrintMaster will save the PDF file to the folder you selected.
11. Open the file in Adobe Acrobat to make sure all the elements and pages are there and that it looks as expected.
