Question about Technics SL-1210 Turntable
There is power going through my technics 1210,but the platter & strobe light still will not work
The target light shorted out my technics 1210,i replaced the q1,q2 & q3 and also the d3 and it seems that there is now power going through the turntable,but the strobe light,pitch adjuster light and also the platter will not work.I'm just wondering if anyone as any ideas on what the problem is?
Posted by carl giblin on
T-Comtech Repairs
    Guru:
  • 417 Answers
How do you know theres power to the unit if theirs no strobe light pitch adjuster light & the platter doesn't spin?
the power comes in & to the transformer first,then through the strobe switch, the transformer is what blows when you short the target light out.....i've seen this many a time when people try & change the target lights to blue neon.
Posted on Mar 07, 2013
  • carl giblin Mar 07, 2013
    well i'm presuming there is power going through it because the lights where the 33 & 45 rpm button are,they are actually on but they stay lit up for some unknown reason.
1 Related Answer
Anonymous
  • 515 Answers
SOURCE: 1210 mk 2 strangeness
Check that your voltage settings are set correctly. This is located underneath your turntable platter. If you remove the slipmat, you will see 2 holes on the metal platter. Rotate the platter till you see the voltage switch, located @ the 9'o'clock position. Make sure it's set to your correct settings (N.America = 115V / Euro = 220V). If not, you will need a flat head screw driver to switch it. Before you switch it, make sure your unit is off and unplugged. After you swich it, it should be ok.
If your still having issues with the speed and the pop-up light, then there is something seriously wrong, and will need to be checked by a technician. Sometimes a resistor or IC will go bad, causing the speed issue, but for the pop-up light - that's usually faulty wiring generally caused by an incorrect replacement.
Did you buy this new or used? Have you had this serviced recently?
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians
Posted on Dec 01, 2007
Technics 1210 mk2
As everything was normal before you started the work, I'm thinking you might have disturbed something. Such as caused a wiring plug to come loose. Maybe even a bad solder joint somewhere?
Apr 28, 2014 | Audio Players & Recorders
Pitch adjustment
There's a variable resistor with the name pitch besides it... first clean it and then you put your pitch fader in the middle and turn it with a screw driver, put your platter on the unit, the plastic black plate you only have to unscrew and take off , nothing else., but like i said , but the platter on it and watch the strobe lights. Determine first which way you have to screw, it's just whole the time :taking of platter and turn screw a bit(don't forget to take of the electricity when you remove the platter), put it on and do that until the strobe stays steady.
greetings richard
Jan 12, 2014 | Technics Audio Players & Recorders
How to replace target bulb in 1210?
Instructions on replacing your pop-up bulb can be found here: <a href="http://1200s.com/Service/Tech/Settings/pop-upbulb.php">REPLACE TECHNICS POP UP LIGHT / BULB</a> - OPTiC The ORIGINAL 1200 TECHNICIAN. www.1200s.com www.djproaudio.com www.djprolab.com Technics DJ Repair Videos Technics DJ Repair Technics DJ Parts DJ Parts DJ Equipment Sales Audio Video Accessories
Jun 03, 2009 | Technics SL-1200MK2 Turntable
Help for technics 1200 MK2 and 1210 Speed is too fast
On the 1200MK2 the pitch control slider is for just that purpose. Disregard the 0 setting and use the illuminated strobe marks on the platter to adjust to nominal speed. When they appear to be motionless you are there. The control on the 1210 may be a knob but the same principles apply.
http://en.wikipedia.org/wiki/Technics_SL-1200
Apr 04, 2009 | Technics SL-1210 Turntable
Target light won't turn off
Your wires are crossed. You'll have to switch them out. Make sure when you put the wires back together, that they are covered properly with either electrical tape, or heat shrink tube. If any part of the wire is exposed and it touches the cabinet, it will ground/short out your turntable, and you'll have an even bigger and more expensive issue to fix.
- OPTiC
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Mar 30, 2009 | Technics SL-1210 Turntable
Technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
May 24, 2008 | Technics SL-1210 Turntable
Platter or motor or what?
Been seeing a lot of problems like this on the newer decks. if the lights instead of moving smoothly are moving a bit, then stopping a little, then moving a bit more. or just wobbling a little bit usually has something to do with the motors... I have also just had to have mine replaced to was having the same problem.... expensive
Feb 16, 2008 | Technics SL-1210 Turntable
Technics SL1200 MK II Speed problem
this one happend to me!! try taking the plastic cover off, under the platter and removing the screws that hold it on if that cures it its because what you ll find is that the screws just catch the underneath of the platter as it rotates. happy mixing
Dec 28, 2007 | Technics SL-1200 Turntable
- TWEAK AV LAB
Dec 01, 2007 | Technics SL-1210 Turntable
Technics 1210 mk2 problem with pitch and lights
- TWEAK AV LAB
Nov 30, 2007 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
235 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
