Question about Watches
How to fix the time and date - Watches
Posted by stevens jolicoeur on
  • Watches Master
  • 18,429 Answers
Unscrew crown pull out to first position turn crown to alter date, pull crown out to second postion to alter time push crown back in and screw down
Posted on Mar 04, 2013
The date of my Swatch changes in the after at 1.30PM. How to fix this
The time set is 12 hours late. When it changes date at 1:30 pm, advance the time by 12 hours.
Nov 04, 2013 | Watches
How to fix the date on my watch
Hold down the mode button until the time is flashing, then press the mode button to cycle through to date, then press the set button (the one that isn't mode) to set the date. Finally, press the mode button until the numbers stop flashing.
Oct 23, 2012 | Watches
Date will not foward but time on watch is running fine i can adjust the date but it doesnt move even though the time has advanced
the date wheel of your watch has a problem, it has to be fix by timex watch technician. or someone that is good in handling a timex module.
Jul 11, 2011 | Timex 27191 Wristwatch
Fix date n month on wrist watch
mcdevito75 here The stem has 2 positions, we all know the 1 to pull the stem out and set the time, day, date. try this, first go thru the watches 24 hour cycle to get the month you need, now slip a fingernail just under the stem (crown) and gently lift to it"s first position, it may take a few times to get used to, when you have it turn the crown (stem) to change the date easily, change the date to 1 date before the date you want, now go thru the watches 24 hour cycle to get to the date you need. Now the watch is set and will change on time at around mid--nite.
Jul 19, 2010 | Pulsar 5117 Wrist Watch
Ots sport watch setting instructions ???
My watch is OTS T6320G ,kindly advise as I want to fix time and date
Apr 14, 2010 | Bulova Watch
Time / date adjuster on my Seiko SNAA63 falls out
Sounds like the mechanism that hold the adjuster in is damaged, im afraid you'll have to get it fixed again
Jun 18, 2009 | Seiko Chronograph SNAA63 Gents Watch
Pulsar (Seiko) Watch Changes Date at different time.
mcdevito75 here, The manufacturer recommends you don"t try to change the date between certain hours as this could hurt the date changeing mechanism inside the watch, I don"t think you did any harm (LUCKY) and the date changeing 45 minutes before mid nite is just about right. BUT! if the date change was aliitle closer to mid nite at 1 time you can try to reset the date, here"s how, your stem should have 2 positions to change the date without haveing to cycle the watch the 24 hours 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it:s first position, it may take a little practise but you"ll get it, once you do, trun the crown and you should see the DATE change, if so set the DATE to 1 DATE before the DATE you want, now pull the stem out and set the correct gate and time of day. Your watch is now reset and date will change on time, around nid nite.
Jun 10, 2008 | Pulsar Bracelet PXQ502 Wrist Watch
Date changes at the wrong time.
The hands must be adjusted.fairly easy fix
Sep 27, 2006 | Baume Et Mercier Baume & Mercier Capeland...
Watches Logo
56 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
