Dec 28, 2010 - 11 posts - ‎9 authors
It would do this in seconds. the screen would just turn black, like it does when you tap the .... Hi do you know hw to reset the wopad and how to eliminate this *process ...Now I can always turn it on, even after a long standby.
Jan 31, 2013 - 9 posts - ‎8 authors
How do you factory reset the nabi tablet 2? My child put ... Turn off your Nabi (To turnoff Press and hold the Power button for 3 seconds) then tap OK 2. Press the ... From your screen press the Volume ? (Low/Down) then the Volume + (Up) button. 5. Press the .... These Before & After Couple Photos Just M..
If you have forgotten your 4-digit pin, the only solution is to do a factory reset. Here are the instructions on how to perform a factory reset: nabi Show the world what you can do
The easiest way to work around a lost password is to do a factory reset. Some tablets will let you change a forgotten password with an email link, but it doesn't always work. Just remember when you reset your tablet to factory, you will have to redownload any apps you installed yourself. It's just like out of the box again. Set up your new password and accounts after you reset.
Nabi website has directions:https://www.nabitablet.com/
Basically:
1) tap on mommy/daddy mode
2) click "Forgot Password" link
Nabi will send you instructions to the mommy account email.
If that fails, you can go to settings and do a factory reset to start all over.
There are two types of resets that you can perform on nabi - forced reboot and factory reset. In the unlikely event that your nabi becomes unresponsive, you can easily perform a forced reboot. A factory reset is recommended when slow performance persists or if you want to wipe out all of your personal data and settings from nabi. Forced Reboot: To perform a forced reboot, hold the Power Button down until nabi turns off. When nabi is off, press the Power Button to turn on nabi again. Factory Reset:Caution! A factory reset is a very serious process because it will SYSTEMATICALLY WIPE ALL USER DATA from nabi. A factory reset will return nabi to its original factory settings.To perform a factory reset from Mommy/Daddy Mode, tap All Apps > Settings > Backup & reset > Factory data reset > Reset tablet > Erase everything. Please note: We highly recommend backing up your nabi prior to performing a factory reset. You can back up your music, videos, photos and apps with nabiâ„¢ Sync.
as an adult,in order to operate that tablet,an adult needs to set up an acct online in order to use it,therefore you would know how to change the password
