Location of fuel pump relay on 2001 e-450 v-10?
The Fuel pump relay is in the Power Distribution Box under the hood, it is relay K. If it is the fuse then fuse 17 in the PDB.
It could also be the cut off switch, which is either under the dash above the brake pedal or behind the passenger kick panel
The fuel pump shut-off switch is
located in the passenger's foot well,
by the kick panel.
i dont have any fuel to motor and cant find fuel pump relay to check it.
Fuel pump Relay or Cut off switch? Did the fuel pump just stop working?
did u see if the fuel pump cut off switch is tripped?
fuse #19
19 20A** Fuel Pump Motor
Where is the fuel pumpcut off switch?
I have a 2002 E450 and all of a suddon fuel pump quit running.
no fuel
fuel suddenly stops, then engine starts up again
