Question about Apple iPad 32 GB WiFi Tablet PC
Ipad screen froze up
Screen froze up
Posted by prcamom2000 on
Susan Torsch
    New Friend:
My candy crush game is frozen what do I need to do?
Posted on Mar 09, 2013
Playing high level candy crush out 2/10/16 tried to buy extra moves to beat level game froze and went back to home screen.Now game takes long time trying to load, fails and goes back to my home screen
I'm certainly not a gamer, but in this case try restarting the iPhone.
If that doesn't help remove the app and do a fresh re-install from the app store. In-App purchases can be restored. I'm not sure if you retain your game status - again i'm not a gamer.
Why doesn't the touch work on my ipad
The iPad's touch screen should always work, unless it froze. Try and restart the iPad (hold down the button on the top edge, close to the camera lens until the iPad turns itself off, normally a few seconds). If it doesn't work after a restart, you may need to reinstall the system, which you can do from iTunes (attach the iPad to your computer, open iTunes and choose 'Restore iPad' - you need internet connection to download new system). Have iTunes back up your iPad before restoring it, if possible, or data will be lost.
If none of this is possible, you may need a repair at a service centre. Good luck! :)
My iPad has froze up and I can't get it off and lock
Try pressing the home and lock/unlock buttons on your iPad for about 10 seconds. The iPad should restart and soft reset. This won't delete anything. It will just force it to restart.
Frozen page in an E book novel. Can't go forward or backward. Everything else works. I can return to home screen but not to library. Touch does not respond on the page which froze. Thanks
There usually is a reset pinhole where a straightened paper clip can be inserted to press an internal switch. this hole is usually on the edge. press and hold the switch for up to 10 seconds lightly. then the ereader should restart
My screen froze. I did a hard shut down. When it turned back on, under settings it reads, Wi-FI Not Connected. When I type in the password it reads not the correct password for this device. We hav
connect other device. If connected then the router is OK. But if not, reset the router( or just power off then wait for about a minute or more then power it on).
or in your ipad, go to settings>>>>> then general>>> then reset>> select reset network settings.
hopes this will help
3answers
My ipad is stucked.
This tutorial will explain how to force your iPad to restart if it gets stuck or freezes up.
Forcing your iPad to restart will not cause any loss of data - with the possible exception of any work you were doing at the time the iPad and/or App froze, forcing you to restart it.
Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom). Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
Tapped out simpson cheat
Well first I would like to say don't and I repeat don't buy cheats EA is very strict on this and could ban your account for doing so.
1. Depending on how its froze up you could try restarting the app itself. Double press the home button (the round one) and you will see a list of running apps pop up depending on ur ios version u should just be able to slide it up and off the screen. Then try to restart the app.
2. If it still doesn't work restart your ipad by holding the button on the top button and slide to power off. Once it comes back on try again.
3. Next try to delete the app by pressing on it and holding. The apps will begin to shake and you may delete it from there. Once its deleted restart the ipad then reinstall it from the app store.
4. Finally would be doing a hard reset. Hold the "Sleep/Wake" button on the upper right of your iPad along with the circular "Home" button on the lower middle part of the device's bezel. After 10 seconds, you should see the Apple logo.
5. If none of these work you may have an ongoing issue that you will need to wait for an update from EA to fix.
Ipad wont turn on
Hold the lock button in until it restarts and when it does restart it again to make sure it's fine . If the problem persists and it flatly won't turn on you should probably get it checked out .
Apple iPad 32 GB WiFi Tablet PC Logo
Top Apple Tablets & eReaders Experts
nexrad_chris
Vernon Taylor
NOEL
NOEL
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
