Question about Chevrolet 2005 Chevrolet Silverado 2500HD Work Truck
2500 duramax will not stay running without manualy priming the pump
Pulled out of driveway after warming up, and just died. will not start unless you pump it with the manual pump
Posted by Kelliel Lay on
Bogdan Odwazny
  • Chevrolet Master
  • 6,158 Answers
Replace fuel filter.
Posted on Mar 06, 2013
Duramax diesel
check fuel pump , and filter for blockage.
Aug 28, 2014 | Chevrolet Silverado 2500HD Cars & Trucks
2003 chevy 2500 duramax dieasal
Diesels run on two fuel pumps. It sounds like one of them is dieing or on the way out. You need a pressure tester to be sure. If you try to fix this one yourself you may just end up throwing a ton of money at the problem without getting a solution.
Oct 06, 2013 | Cars & Trucks
2003 chevy 2500 duramax diesal
when was the last time you cleaned the fuel filters. also there is a breath vale that opens when the engine is started so the fuel runs easier if this is blocked or not working will give the same results as you are saying..
1998 gmc 2500 sle 5.7 wont stay running
Theres only one fuel pump relay, unless you have dual tanks. Be sure you have 55-60 psi fuel pressure. I "think" the oil pressure switch supplies power to the fuel pump after the engine is running.
Dec 14, 2009 | 1998 GMC Sierra
1998 gmc 2500 wont keep running
The anti thieft system is keeping it from running.
Dec 13, 2009 | 2004 GMC Sierra 2500
2007 chevy silverado 2500 hd duramax shut down
mo me it sounds like low fuel volume i would check my lift pump
Sep 30, 2009 | 2007 Chevrolet Silverado 2500HD
2003 GMC Duramax Diesel won't start
I see that you had the injectors replaced 20,000 miles ago. I would still check the oil to make sure it is not overfull. The new injectors could be bad. If the oil level is not overfull then get a paper towel and touch the dip stick tip on the paper towel while oil is on the dip stick. If it's only oil it will not spread. If it has diesel in the oil the oil with spread. If this test doesn't show the injectors to be bad then you have three other possibilities. The FICM (fuel injection control module), the fuel pressure regulator, or the injection pump. It's hard to pinpoint what the problem is without running more tests and the only way to run those tests is with the computer the dealership has. Just so you know your injectors are still under warranty until 100,000 miles. Most likely you will have to take it to the dealership to get you truck fixed. I hope this helps you some.
Jan 05, 2009 | 2003 GMC Sierra
Chevrolet 2500 Not Running, May Be Fuel Filter Sensor
if it dont have good compression it will not start check the comp and make sure there no water in oil if fuel pressure is low it will not pop the injector open try some starting fluid
Dec 18, 2008 | 2001 Chevrolet Silverado 2500HD
That red wire is only for the fuel heater.will not cause a no start.try pumping the primer pump on top of the fuel flter hsg. but first open the bleed screw,which is black plastic also located on the top.this will eliminate any trapped air that might have entered the fuel intake system.if the pump does not get firmer and harder to push, then you have a leak in the fuel supply lines or the ck valves in the fuel filter hsg or stuck open. Still no start have it scanned to ck fuel pressure while cranking.it should be close to 5000 lbs
May 14, 2008 | 2003 Chevrolet Suburban 2500
Chevrolet 2005 Chevrolet Silverado 2500HD Work Truck Logo
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
Glenn Smart
Glenn Smart
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
