If you are talking about the handle-bar stem, the bolt you need to tighten is right in the middle of the post. It may have a snap-on plastic cover over it. This will be the head of a long bolt that reaches down inside of the stem where the nut is shaped as a wedge that serves to tighten inside the tube of the front fork. If you are talking about the the seat-post, then your seat-post might be of too small diameter.This page shows a good picture of the handle-bar stem bolt and wedge nut.
http://www.bikewebsite.com/bikeoh.htm
SOURCE: making the bike from a 18-speed to a 1 speed bike
single speed bikes have a single ratchet or fixed sprocket with no offset of the spokes, so you would probable need another rear wheel.
Another derailleur is probably simpler, try ebay
SOURCE: We have an 18" boys huffy bike and the chain keeps...
If a single speed bike loosen the rear wheel and pull it back away from the pedals to get the chain tighter
If it has multi gears the arm hanging down has a ser screw that will need to be adjusted to align the chain to stop at the last gear
SOURCE: can I replace the back
That's up to you and your abilities and available tools...
http://www.parktool.com/blog/repair-help/categories/hub-service
SOURCE: i have a late 70's huffy saratoga bike that came
All you have to do is put a distilled version of your request into a search engine "adjust shimano 3 speed internal hub" and voila - videos and other resources.
http://www.parktool.com/blog/repair-help/internal-gear-hubs
SOURCE: Huffy 18 speed multi terrain
Web search just about anytthing in a short concise way like "how to adjust derailleur" and get an instant answer.
Good resource http://www.parktool.com/blog/repair-help/categories/derailleur-systems
