Question about Dell Inspiron 2200 Notebook
Dell inspiron 2200. The DVD ROM can read DVD's but Im unable to boot from it with a boot disk.
DVD ROM IS WORKING JUST NOT ABLE TO BOOT FROM IT WITH A BOOT DISK THE BIOS IS SET TO BOOT FROM DVD ROM.
Posted by Carl on
Randal Lovelace
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 112 Answers
Have you verified that the disk you are trying to boot is bootable and not damaged on it's boot sector?
Does the drive read other DVDs (after boot into OS?)
Posted on Nov 21, 2013
5 Related Answers
Pyrhyc
Ryan Rogers
  • 2028 Answers
SOURCE: Laptop does not Boot - Screen Blank -- Fan On
Sounds like your hard drive may be going out, do a check disc.
Posted on Jul 11, 2008
Anonymous
SOURCE: dell inspiron 6000 invalid configuration information
rebooting system fix issues many a times..
Posted on Jan 14, 2009
shashank rai
Shashank Rai
  • 60 Answers
SOURCE: driver for inspiron 1300 dvd RW
1300 comes with a dvd combo so you cant find it on dell's officeal site.
Posted on Apr 27, 2009
Anonymous
  • 8 Answers
SOURCE: DELL Inspiron 6400. CD/DVD ROM cant read any
all you can do is uninstall the drive from the device manager and delete the upper filter and the lower filter in the registry NOTE: please enter the registry at your own risk. To enter the registry click on Start>>>Run and enter regedit in the run command. The path to delete the upper filter is hkey local machine\system\currentcontrolset\control\class\{4d36e965-e325-11ce-08002be10318 click on the folder and delete the upper or the lower filter or both and then restart the computer. Hope this helps
Posted on Jun 08, 2009
Harrel Abalo
  • 107 Answers
SOURCE: Dell Inspiron E1505 CD/DVD Drive reads only dell disks.
If the driver didnt fix your problem, your disk drive might be faulty , maybe the problem is on the disk drives lens this is very common problem 2 any other cd/dvd rom drives.
Posted on Jun 26, 2009
PC turns on but will not boot up; unable to run directly from cd rom
Just before it boots, press the button, (F1. F2, Esc etc) to gain bios screen. Set the boot drive to DVD ROM. Insert your boot disc and re boot.
Nov 21, 2013 | Dell Inspiron 1545 Notebook
Dell inspiron n4010 optiarc DVD+-RW -AD7700-H driver
Boot into Safe Mode by pressing F8 during boot. Right click My Computer and Manage. Check for hidden devices ubder View and delete all CD drives. Reboot and Windows will auto install.
You have a bigger problem if it fails to install and work. Then I would try re-seating the drive physically. GL
Dec 26, 2012 | Dell Inspiron 14R (N4010) and 17R (N1710)...
Im not able to boot from os cd the bios can see rom drive and hard drive but im not able to boot iv'e tried f12 but no joy can you help?
hi there.
If you go to the bios on start up and select cd rom drive as your primary boot and then restart. Your computer will then try to boot first from the cd rom drive and second from the hard drive. If it fails to boot from the disk then this would lead me to believe that either the disk is unreadable by the drive or that the cd rom drive itself is unable to read the disk.
Jun 30, 2011 | Dell Computers & Internet
Installation problem
well thats frusterating somtimes, i can tell you the problem might be a disk read error, that means or your disk or the cd-rom, and it might be a ram problem, so try different disk....under different burning sppeeds......
May 07, 2010 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
How do i restore my hard disk in my dell inspiron 2200, it's not booting up
"Ctrl+F11" pressed together at boot up should get you into the Dell System Restore tool.
Feb 27, 2010 | Dell Inspiron 2200 Notebook
Jun 26, 2009 | Dell Inspiron E1505 Notebook
Dell laptop inspiron 1000
Put recovery disk in the CD drive. On reboot, hold down F12 key. You should get a choice of drives to boot from. Make sure the first two are in the correct order:
1. CD-ROM (optical drive)
2. HDD (hard drive)
then press F10 to save and exit.
Now the laptop should boot correctly from the recovery disk.
Jan 06, 2009 | Dell Inspiron 1000 Notebook
Dell Inspiron-1520 unable to read RW DVD's.
you have a faulty disk inserted in the drive. Restart the computer and continuously press eject while the pc is booting, it should eject then.
Oct 11, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Doesnt boot from DVD rom
Hi
I know it sounds a bit odd but were u using a bootable disk to boot?
If yes, then try epgrading ur BIOS version it may help.
Jun 01, 2008 | Dell Inspiron E1405 Notebook
DVD ROM
Have you tried using a lense cleaner disk?
Can you hear the disk spinning at all?
Is the problem with both cd and dvds?
What kid of disk are you trying to play? Some dvd roms will not read dvdrw disks.
Dec 28, 2007 | Dell Inspiron 2200 PC Notebook
Dell Inspiron 2200 Notebook Logo
140 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
