Televison & Video Logo
Question about Sanyo AVM-2506 TV
T.V ONLY HAS NO INPUTS
WHAT ADAPTER DO I NEED TO HOOK UP A IPAD DIRECTLY FROM T.V
Posted by NANNETTE HERNANDEZ on
Anonymous
    New Friend:
  • 4 Answers
U need an ipad audio/video connector. One end is the plug at the bottom of the ipad, the other end is a red/white/yellow tv connector. Get a genuine apple one, not one made by other companies, or they wont work, apple has blocked 3rd parties from certain items, and thats one of them. It costs $50 new, or you can find it on ebay used for alot less, just make sure its not a cheap knockoff and its the real one.
Posted on Mar 03, 2013
tip
How To Connect Flat Panel TV to Computer
Hello <br /> First identify your TV's input connections. Most TVs these days have three basic types of inputs. You have your coaxial cable input, the same as your cable box or satellite, an RCA composite input (the yellow, red and white inputs) and an S-video connector. Newer televisions might have Component Video, DVI, VGA or HDMI inputs but the ones listed above are more common. <br /> Identify your computer's outputs. These days computer manufacturers are adding TV compatible outputs on their products so it's easy to have a pc to tv connection when you hook it up. The S-video in particular seems to be popping up on more and more computers, so a PC to TV S video connector might be what you need. You can shop for S-video cables all over the place online. Mostly you will find the usual VGA output that the regular monitor hooks up to (see more later on VGA cables). The newer multimedia computers will probably have all high definition outputs that connect directly to your HDTV, but for now we will deal with what most people have for both computers and televisions. <br /> Find the appropriate adapter for your connections. You may need to get a computer to TV cable so you can hook up your computer to the TV. If you have an HDTV, you may need a VGA to component cable. This VGA to component cable connects your computer to a HDTV and acts as a converter. (And that computer could be either a Mac or a PC.) <br /> A PC to tv connector has a VGA adapter on one end and (usually) a selection of connectors on the other (S-video, RCA composite and Component). The good thing about these is that you can take it from TV to TV and you'll be able to hook up computer to TV for all of them. I highly recommend a wireless adapter. It costs a bit more but wireless is worth not having a big cable mess and not keeping your computer near your TV. <br /> or you can get help from this video <br /><br /><img src="utube.png" /><b><i> You-Tube video "ZCN-nN1orYE" placeholder (do not delete) </i></b><img src="utube.png" /><br /><br />Hope this helps, if so do rate the Tip.<br />
on Jan 25, 2011 • Televison & Video
2answers
How can i sync to my hisense tablet
Search Results
    How do I sync my ipad with my smart tv ' Apple Support Communities
    discussions.apple.com > Support > Apple Support Communities
    Apple Inc.Feb 20, 2014 - Get an Apple TV to hook up to your smart TV and connect via AirPlay or use the Digital AV adapter. Apple TV: ...
    Use AirPlay to wirelessly stream content from your iPhone ...
    https://support.apple.com/en-ie/HT204289
    Apple Inc.Nov 11, 2015 - And with AirPlay Mirroring, you can display your iOS screen on yourApple TV. ... For music: Apple TV, AirPort Express, or AirPlay-enabled speakers. ...iPhone 5 or later; iPad mini or iPad (4th generation or later); iPod touch ...
    Can you link icloud with an android tablet? ' Apple Support ...
Why wont my ipad charge
To charge an iPad you have to connect the USB cable to iPad power adapter (12W in power and is bigger in size compared to iPhone's). If you connect it to iPhone power adapter you might see that the iPad is not charging, but will take a very long time to charge. The same goes with connecting directly to computer.
Also, there is always a chance that either your cable, or adapter or the iPad itself has gone bad.
Pro 70 lavalier mic- is there away to hook the pro 70 lavlier directly to your computer or mic WITHOUT a mixer or amplifier?
On microphone input of your soundcard if it is not there then sorry you need a tiny amp as the other inputs are all at line level
4helpful
5answers
Adding music to iPad
You can add music to the iPad by directly downloading from the iTunes app or by importing your music into iTunes on a computer. Once your music is imported/downloaded into iTunes on a computer, you then just need to sync the music by connecting your iPad to a computer.
11helpful
2answers
How do I hook up my hp computer to my lg flat screen tv
You can use the TV's VGA port which needs a VGA cable which you can get from a computer hardware store. It's called RGB in on your TV. This is also called PC input.The max resolution you will get is 1,366x768 off your PC.
1helpful
I just want to know how to hook up a hdmi cord to an old big screen hitachi tv
You can't, at least not directly. Older sets don't have any HDMI inputs, only composite video (the yellow RCA jack) and possibly component video (red, green and blue RCA jacks). Converters that take an HDMI input and generate the necessary video outputs are available, but they aren't cheap. And don't fall for the adapter cables you might find advertised with an HDMI plug on one end and RCA plugs on the other that supposedly convert the signal for you. HDMI can only be converted with some active electronics; a simple cable just won't work. If you want to hook and HDMI-only device to your old Hitachi, you'll need the converter.
2helpful
3answers
Hook it up to the tv
If your hooking it directly to the tv depending on how old the tv is use one of the inputs. Hook the two red and white to red and white and the yellow to the video in input. If it's an older tv you will need whats called an rhf adapter. Hook your color codes together and use a cable cord to go from the antenna out to the tv's uhf input. I hope this information was helpful........... : )
1helpful
2answers
Factory stero to amp
If the amplifier has inputs for a high level signal, you unhook the wires going into the speaker and plug them into the amp, then hook the outputs up to the speakers. If the amp only has rca inputs, you need to also buy a line level converter. Then you unhook the speakers, hook the wires up the the converter, then hook the converter up to the amp, then hook the amp up to the speakers.
Please leave good feedback!
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
